Neutral safety switch 67 Cutlass
Old February 24th, 2017, 04:09 PM
Kid Thunder's Avatar
All of a sudden the car wouldn't start. But if I banged it into park it started.
Is the neutral safety adjustable? It looks like it is. Or is it bad?
Kid Thunder is offline
Old February 25th, 2017, 01:00 AM
Supernaut72's Avatar
Could be either or. Recently while replacing my brake booster/master cylinder the easiest way to get to one booster mounting nut was to remove the neutral safety switch, and when I initially threw the switch back in, the car would not start. After an adjustment, it would start but would have the reverse lights on in Park. Took some trial and error in my case, getting everything positioned just right for it all to work as it did before I removed it, so yes definitely adjustable.
If you haven't touched yours before this problem occurred, might want to pull it out and have a good look at it to make sure it's reasonably clean. Make sure to find a way to mark where it currently is, assuming it hasn't been moved since it started acting up.
Supernaut72 is offline
Old February 25th, 2017, 03:49 AM
Yes its adjustable.
oldcutlass is offline
Charly9g
November 6th, 2016 05:10 PM
oldspackrat
November 17th, 2014 06:31 AM
OKIEOLDS
August 8th, 2011 05:17 PM
56convt
July 24th, 2011 07:13 AM
70 ctls
January 28th, 2009 03:20 PM
Quick Reply: Neutral safety switch 67 Cutlass
