Neutral safety switch for 70 cutlass floor shift
Old June 16th, 2010, 02:22 PM
OKIEOLDS's Avatar
Does anyone know where I can pick up a neutral safety switch for my 70 cutlass vert with a floor shift?
OKIEOLDS is offline
Old June 16th, 2010, 02:26 PM
Lance
ROCKET VAPOR's Avatar
I think Fusick has them.
ROCKET VAPOR is offline
Old June 25th, 2010, 12:16 PM
OKIEOLDS's Avatar
Ok I will check there...thanks
OKIEOLDS is offline
Old June 25th, 2010, 12:26 PM
dhartley72's Avatar
autozone $7.99 and orileys autp part 28.99.....i had the same same on a 72 cutlass a moth ago.... the 7.99 works great.....is your car cranking up in reverse?
dhartley72 is offline
Old June 25th, 2010, 09:20 PM
Boldsmobile's Avatar
That NSS should be mounted to the shifter if iirc. Not likely to find one at az or o'r.
Was Parts Place selling them?
Boldsmobile is offline
Old June 27th, 2010, 07:54 PM
Just the facts...
BILL DEMMER's Avatar
there is also the possibility of repairing the one you have, if worse comes to worse. find someone with GOOD soldering skills. i fixed mine up for ernie, and a spare too.
bill
BILL DEMMER is offline
Old July 4th, 2010, 06:55 PM
Classic GM Fan
mv213's Avatar
They are made by The Parts Place. Here's a pic of mine: https://classicoldsmobile.com/forums...tml#post184363
I don't think the ones from the auto parts stores are for the floor shift.
mv213 is offline
Old August 7th, 2011, 08:48 PM
OKIEOLDS's Avatar
I still have not found a neutral safety switch does anyone know anbody that carries them?
OKIEOLDS is offline
Old August 8th, 2011, 05:39 AM
The Parts Place has them. It was around 70 bucks if I remember correctly.
matt69olds is online now
Old August 8th, 2011, 05:17 PM
Classic GM Fan
mv213's Avatar
That's too subtle, two other people already mentioned the parts place.
THEY ARE HERE: http://www.thepartsplaceinc.com/newp...+safety+switch
mv213 is offline
oldspackrat
November 17th, 2014 06:31 AM
Olds Dad
September 26th, 2011 04:18 PM
72' Convertible
May 21st, 2009 12:46 PM
Flye
March 30th, 2009 03:45 PM
70 ctls
January 28th, 2009 03:20 PM
Quick Reply: Neutral safety switch for 70 cutlass floor shift
