Wiring accessories to key on position?
Old April 12th, 2018, 12:53 PM
Joe Ralph
72442455's Avatar
I’ve dreaded asking this for some time now as it’s complete newbie question - but - I want to wire up a usb in place of my cigar lighter in a 72 convertible - I am also interested in going to HEI distributor - BUT! - this apparently is so easy a job that every you tube video and post I can find simply “yada yada’s” over the details - they simply say “just wire it to the key on position” my radio is currently a wire wrapped around the end of the glass fuse 🙁 - any good links on a detailed correct way to wire accessories into a 72 GM a body? I have simply just never learned how to do this correctly and neatly - any advise would be greatly appreciated - thanks in advance ~ Joe
72442455 is offline
Old April 12th, 2018, 01:15 PM
In the center of the fuse box is a terminal marked IGN which is a switched 12 Volt source. Put a female spade terminal on the HEI battery + wire and connect it there.
For your radio power, there's that switched IGN terminal and a constant power BAT terminal in the center of the fuse box, depending upon which one you need.
If you need to power two things off one of those terminals, use one of these:
Fun71 is online now
Old April 12th, 2018, 01:54 PM
Joe Ralph
72442455's Avatar
accy = ignition? And not sure that spade will fit my situation (72 cutlass)
72442455 is offline
Old April 12th, 2018, 02:01 PM
Joe Ralph
72442455's Avatar
N/m I see that the plug under it is ignition - In my pic does my battery terminal look correct? That spade will plug into that to wire battery direct? And just split the ignition for hei and lighter?
72442455 is offline
Old April 12th, 2018, 02:19 PM
RandyS's Avatar
I believe if you pull the grey connector off of that terminal, you will be able to put an adapter on it and re-attach the grey one and add one more. There are a couple of styles of adapters, I like this style: https://www.digikey.com/product-deta...8-1-ND/1131814
There are also these which let you tap off of any fuse in the box: https://www.waytekwire.com/products/1495/Fuse-Holders/
RandyS is offline
Old April 12th, 2018, 02:47 PM
Joe Ralph
72442455's Avatar
very cool - I will check it out second I am able - I can immediately think of severa things I’d like to run off of this - hei, lighter, electric fuel pump, maybe electric fan? Is there a limit to jumps? Is this where I would run the lead to an “add on” fuse panel if I wanted? Do I put a fuse in the wire somewhere for this? (Sorry for all the questions) thanks! ~ Joe
72442455 is offline
Old April 12th, 2018, 03:21 PM
therobski's Avatar
I installed a USB charging port where the cig lighter was-has a blue LED light for 64 F-85 Pro-Touring build. Have not tried it out yet. I wired this and a bunch of new accessories to a Painless 7 Circuit boss and did not use the original fuse panel.
therobski is offline
Old April 12th, 2018, 03:27 PM
therobski's Avatar
Especially if your going to think about electric fans, amplifiers, A/C etc. Just my thinking.
Old April 12th, 2018, 03:57 PM
RandyS's Avatar
I would have to agree with what Rob posted. You can tap a little bit from your existing fuse panel (HEI, Aftermarket Radio), but for fans, big amplifiers and such, I would recommend an add-on fuse panel. The add-on can be in the engine bay, like Rob's, or under the dash near the existing one, your choice. Google adding a fuse panel to your existing electrical system.
RandyS is offline
Old April 12th, 2018, 04:33 PM
Joe Ralph
72442455's Avatar
Thanks Rob! Thanks Randy! I think this is exactly what I was looking for - plus I still like the idea of cleaning up my original under dash fuse box - got some work to do!
72442455 is offline
Old April 12th, 2018, 05:29 PM
therobski's Avatar
The 54 year old fuse box and old wiring is still "good" maybe okay? Its nice to have the new 7-circuit boss to take the load off the old fuse box with the added new accessories. So far its wired to the new Old Air Products A/C system, blower motor for the A/C, Flex-A Lite dual Electric fans, 300 watt Sound Stream amp, a marine head unit mounted in the glove box to drive the sound-set up to stream Pandora etc. from my I phone. I-phone needs more juice plug in in the USB port! When I get this buggy on the road its our RV! for the road cruises.
Old April 12th, 2018, 05:39 PM
therobski's Avatar
Few more pictures for you to get you thinking!!..(Olds) 80's Rubicon Sound stream amp bought on Evil-Bay in the original factory shipping box-$90.00 dollars, 5 years ago. Buddy built the boom box with high powered 6X9 speakers for my for my BD.
Old April 13th, 2018, 05:02 AM
Joe Ralph
72442455's Avatar
I’m miles away from a decent sound system 😜 - gotta get her moving reliably and safely first - then she needs to get pretty again - but I will probably be picking your brain down the road - I love the idea of the Bluetooth stereo with my iPhone as player - I want to mount an original radio in dash with working lights then hide the Bluetooth set up - i bought the same “blue light” usb cigar charger replacement you have - did you say it has enough power to charge your iPhone? I am going to use your idea of the 7 fuse add on - SOooo much to do - so little time 😩 - mine too will be my rv someday!
72442455 is offline
Old April 13th, 2018, 05:06 AM
Joe Ralph
72442455's Avatar
Rob I just looked up a pic of your car on one of your older post - that off set stripe is HOT! What a beauty!
72442455 is offline
Old April 14th, 2018, 07:57 AM
therobski's Avatar
The off-set stripe actually came from dimensions posted somewhere in this Club or Real Olds Power. It was a dealer add-back in 65. My body shop took the dimension's and painted it on, running the strip into the metal part of the dash and out through rear metal window frame area onto the rear deck. The 65 dealer add on was most likely vinyl. I had a plastic OEM very looking radio delete plate for the dash to replace the radio.
Old April 14th, 2018, 08:13 AM
therobski's Avatar
When the time comes to "adding" the goodies, you may think about alternator output. I currently have a 100 amp Power Master alternator. I have not had the car in the street so we will how it goes with all the accessories are on at idle in 100 degree Texas summers. May have to upgrade. And I still need to make or buy a heavier gauge wire from the alternator to the starter. 100 amp alternators should use an 8 gauge wire, I think if I need to move up to a say 130-150 amp I would use a 6 gauge wire. Currently when I had M@H Electric make me a new under hood harness for the HEI, they used stock specs for the alternator wire to the starter.
olds 307 and 403
March 4th, 2018 03:24 PM
Rustbucket2
April 23rd, 2016 12:06 PM
W-27
May 11th, 2014 05:41 AM
86ChebbyWagon307
July 5th, 2011 07:09 PM
Quick Reply: Wiring accessories to key on position?
