Wires needing home in my 68 442
Old September 14th, 2012, 10:17 AM
Coach6's Avatar
I've got a few wires that probably should go somewhere - I'll post the pics and see what you guys come up with.
The first picture will has a dark green and light green wire coming out of the firewall on the drivers side. Thanks
Coach6 is offline
Old September 14th, 2012, 10:54 AM
805cut's Avatar
The first wire i am not so sure about, the second one TO ME looks like it could possibly go to your NSS if there purple, and the third looks like it could be for your stoplight switch if its white. But then again im just looking at the connectors. Since i cant tell for sure what color the wires are (pretty much color blind) haha someone els will know 100%
805cut is offline
Old September 14th, 2012, 11:35 AM
Lady72nRob71's Avatar
Not too familiar with the '68, but here goes...
First one looks to be for a not-so-common option, the giveaway is the three hole option grommet. Any evidence that cruise control was installed?
Second looks to be for TH400 kickdown switch, if wires are pink and orange.
Third looks to be for mirror maplight - I think....
Lady72nRob71 is offline
Old September 14th, 2012, 01:26 PM
805cut's Avatar
see i know everything there is to know. lol
805cut is offline
Old September 14th, 2012, 02:42 PM
Tom442's Avatar
Brown one in the last picture
is for the under hood light!
Tom442 is offline
Old September 14th, 2012, 02:49 PM
allyolds68's Avatar
Is your car a standard trans? The first looks like the backup light harness
allyolds68 is offline
Old September 14th, 2012, 04:05 PM
Nice timing on your original post time - 04:42pm
Old September 14th, 2012, 05:20 PM
Coach6's Avatar
if its the backup light harness - may explain why I don't have backup lights - thanks for the ideas
Coach6 is offline
Old September 14th, 2012, 07:14 PM
Tom442's Avatar
I planned it that way!
Tom442 is offline
Old September 18th, 2012, 03:43 PM
Octania's Avatar
Photo 1 is for backup lighting. There is no other handy mating connector you can use either.
Therefore, you have a MT car, eh?
The switch should be on the trans linkage, hooked to the reverse lever [aftmost] via a 1/8" diameter rod.
Idiot sellers notwithstanding, this is what your trans bkp lite switch DOES NOT look like:
http://www.ebay.com/itm/SMP-STANDARD...a32d02&vxp=mtr
Here's one, DIRT CHEAP too:
http://www.ebay.com/itm/380377501172...84.m1438.l2649
One of your comrades here may have a less spendy and/or used one for you. That's what friends are for. Or, you could certainly adapt say a motorcycle brakes light switch to the purpose. Points off at showtome, but R lites would work.
Octania is offline
Hawghead
July 18th, 2014 12:51 PM
Sampson
February 19th, 2014 03:12 PM
raw442
May 14th, 2013 05:23 PM
dsa2207
Cars Wanted
January 28th, 2013 05:06 PM
Chris Rothwell
June 9th, 2012 07:04 AM
Quick Reply: Wires needing home in my 68 442
