Wire gauge please..
Wire gauge please..
Hi, what would be the original gauge size for the wire that goes from the battery (actually the horn relay) to the "BAT" terminal on the back of a stock alternator (71 442).
Can't see it on the wiring diagram. The one I have if original, is 10 gauge.
Agree w/ everything stated above. I don't have the 1971 CSM in front of me at the moment. NOTE: The 1971 CSM contains a separate B&W wiring diagram for the 4-4-2 model. There are subtle differences between the color A Body "V-8" wiring diagram & the B&W 4-4-2 wiring diagram. The B&W 4-4-2 wiring diagram may well be a 10ga wire.
Purchase an original OEM paperback edition (used) 1971 CSM. Plenty on eBay. You should have this as your bible anyways. Buy an original OEM, not new as new are copies of original and poorly reproduced.
