Right Brake Light Not Working - '65
The right brake light on my '65 doesn't work. Right parking light and right turn signal work, as does everything on the left side.
Based on another thread, it looks like the turn-signal switch. Any other possibilities?
One easy test is to disconnect the plug to the turn signal switch and apply 12V to the wire to the RH brake/turn light. This should be the dark green wire (though I have to admit that the wiring diagram in the CSM calls that RH in one place and LH in another place - the alternative is the black with yellow stripe wire).
Thanks, Joe. Affirmative on the same behavior with running lights on or off.
I did find a new turn-signal switch in my stash, that I did not buy; so it must've come with the bevy of parts that came with the Vista Cruiser.
