Replace disburtor weights?
Piece of cake...just don't loose the tiny little springs when you're sprawled out over your fenders trying to put them in...
And prepare to do it a few times to get the right spring & weight combo.
While it's not impossible for the weights to be bad, I'd want to understand what was "shot" before replacing anything. The two possible failure modes are 1) the weights have rusted in place and you get no advance or 2) the holes in the weights are worn and you get erratic advance. If the latter, it's also possible that the posts that serve as pivot points are also worn, which gets a lot closer to a new distributor. Understand the problem before replacing parts.
Well, again, what exactly does that mean? The two weights pivot out due to centrifugal force. They pivot on small pins. A spring on each weight holds them in place. An ear on each weight near the pivot limits the total travel outboard. The weights don't exactly "spin" and I don't understand what "knocking the advance out" means. If you're saying the mechanical advance is erratic, that's one thing. If you're saying the mechanical advance provides too much advance, you don't need to change the weights to fix that. If you're saying the advance curve is too fast (or too slow) you need to change the springs, not the weights. At the risk of channeling Norm, your statement really doesn't make sense.
I know my engine turns at 3500 RPMs at 65 MPH, It used to be 70 at the same RPMs which is still too high. This happened with no timing changes.
At 3500 RPMs when I had the points I was going 85.
IfI take off the cap and rotor and see the weights. I can move the weights freely back and forth. Is this normal?
The timing is right. I believe it's at 23 not 20. But when my old mech set it at 36 ( ) it's been pretty much the same as it is now
https://classicoldsmobile.com/forums...e-problem.html
This is the third time around. Maybe one, or two, of the laws of physics have changed since the last go around.
Norm
https://classicoldsmobile.com/forums...iming-hei.html
Norm
Norm
BTW the coil is an OE replacement. I'm not spending $50 on a "50,000" volt coil
I know my engine turns at 3500 RPMs at 65 miles per hour, It used to be 70 at the same RPMs which is still too high. This happened with no timing changes.
Get your hands on an inductive tach (the kind that clamps on the spark plug wire) and temporarily install it so you can read the tach while you drive. Compare the reading to your in-car tach, THEN figure out what's going on.
And to answer this question once and for all, yes, it's trivial to replace the weights and springs. Remove the cap, remove the rotor, remove the advance springs, remove the weights. Reverse the process to replace.
RetroRanger
September 12th, 2011 09:57 AM
