No power to the starter "Please Help"
Old May 29th, 2010, 02:02 PM
morrowjm4154's Avatar
Ok, I have recently replaced the wiring harness in my 71 Cutlass and I now have no power to the starter from the ignition switch. There is power throughout the car (lights, radio, turn signals etc) and also power to the starter from the battery. I have tested all of the other connections on the ignition switch on the colom and they are good. I have gone as far as replacing the neutarl safety switch also. I want to point my finger at the horn relay, but do not remember which other wires get connected to it other than from the battery. Please help me out so I can get my car back on the road.
morrowjm4154 is offline
Old May 29th, 2010, 03:41 PM
Step 1: get a test lamp
Step 2: get a Chassis Service Manual and open to the wiring diagram
Step 3: use the test light to trace the circuit at each connector, starting from the fuse panel and find out where there is no longer power.
Step 4: fix the problem you find.
joe_padavano is offline
Old May 29th, 2010, 10:12 PM
svnt442's Avatar
Try this....
svnt442 is offline
Old May 30th, 2010, 06:19 AM
Lady72nRob71's Avatar
Use a thick wire to jump across the neutral safety switch (the two big purple wires). IF it cranks, then either the switch is misadjusted or bad. If the reverse lights come on in reverse, then the switch is in adjustment already.
Lady72nRob71 is offline
Old May 30th, 2010, 08:32 PM
Thank you so much I will give all of these a shot and keep you guys posted on the results/problems that come up.
Big Dawg
October 18th, 2014 06:57 PM
oldsladyliz
Ninety-Eight
August 20th, 2013 02:32 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
morrowjm4154
May 29th, 2010 02:12 PM
Quick Reply: No power to the starter "Please Help"
