inline fuse blower motor
Old May 20th, 2013, 07:10 PM
72Cutlass_Sunfire_Yellow's Avatar
OK the blower motor doesnt work on high so I think the inline fuse is blown -cant get the thing apart though - do I twist, just pull or what? Rubber solvent??
72Cutlass_Sunfire_Yellow is offline
Old May 20th, 2013, 08:02 PM
Push the two halves together, twist about ¼-turn counterclockwise, and pull away.
MDchanic is offline
Old May 20th, 2013, 08:08 PM
oldspackrat's Avatar
What Eric said. Usually the metal ends of the fuse rust/corrode & you'll end up breaking the glass between the two if/when you do get it apart. You will have to dig the ends out & clean & install a new fuse then. That special length fuse is not easy to find either if I remember right.
oldspackrat is offline
Old May 21st, 2013, 06:31 AM
hookem horns's Avatar
Hope it comes apart easily. Before tearing anything up though, use a voltmeter to see if you have power up to the fuse but not after. If not concerned about originality, you can replace the old fuse holder with a modern blade type from any parts store.
hookem horns is offline
Oldscutty72
December 28th, 2015 01:56 PM
neatolds
August 19th, 2015 11:40 AM
mmurphy77
June 17th, 2014 12:49 PM
johnnyhawthorn
March 12th, 2014 05:10 PM
gstangl
July 20th, 2006 08:53 AM
Quick Reply: inline fuse blower motor
