Horn Help
Old February 3rd, 2017, 02:54 PM
Kurtzk's Avatar
Horn Help
I just rebuilt the steering column on my 79 Cutlass. I got everything done and when I reconnected the wiring harness the horn stays on. I have a billet specialties steering wheel, and all the connects are ok. Did I blow a relay or something? Thanks in advance -K
Kurtzk is offline
Old February 3rd, 2017, 04:01 PM
You need to go back and check your connections. You have a short somewhere in the way you reassembled everything. The horn relay is activated by a ground (the black wire) that feeds from the steering column.
oldcutlass is offline
joepenoso
July 12th, 2013 11:03 AM
DennisG.
April 15th, 2012 11:01 AM
theoldsrocket
April 27th, 2011 06:17 PM
kimberlies7
August 28th, 2009 03:03 PM
Joeypete
May 28th, 2009 05:17 AM
Quick Reply: Horn Help
