Generator Rebuild or Upgrade
Old November 3rd, 2016, 06:14 AM
farmer52's Avatar
If you been reading the thread about my late brother's 1972 Supreme, I am in the process of getting it running and eventually roadworthy. Since the car has been sitting for ~30 years, I am thinking of either rebuilding or upgrading the generator. If the CSM is accurate, the standard generator is a 37 amp. The car has no A/C and no power accessories other than an AM radio. No plans at this time to add A/C or accessories. Should I run it as is, rebuild, or upgrade to a 55 amp? TIA for your comments.
farmer52 is offline
Old November 3rd, 2016, 06:33 AM
stellar's Avatar
If the alt is working, I would run it as is. If you rebuild it yourself I would rebuild as 37 amp. If sending it to a shop for rebuild, I would ask for an upgrade.
stellar is offline
Old November 3rd, 2016, 06:39 AM
farmer52's Avatar
I do not know if it is working since it has been sitting so long. I would attempt to rebuild it myself. I also realized it has an external voltage regulator.
farmer52 is offline
Old November 3rd, 2016, 06:53 AM
jaunty75's Avatar
I don't see the point of rebuilding or replacing an alternator that works, and apparently you believe the original one works because you say one of your options is to use it "as is." If you do have to replace it, you don't need a more powerful one because, as you said, the car has almost no accessories. Whether the original or a replacement, why wouldn't one the size that came from the factory be adequate? I don't think the factory made a habit of installing underpowered alternators.
jaunty75 is offline
Old November 3rd, 2016, 08:04 AM
farmer52's Avatar
Thanks for the replies. It was working (to my knowledge) when parked in 1985. I think I am going to rebuild because the car was sitting so long. I am concerned about internal corrosion because of sitting on dirt/gravel. Lots of surface rust everywhere in the engine compartment. Is there a part number stamped on the housing? I cannot see one. Thanks again everyone for your input.
farmer52 is offline
Old November 3rd, 2016, 08:15 AM
jaunty75's Avatar
OK, that looks a little rough. If you do need to do something, is there any particular need to rebuild this one? I put an alternator (your car has an alternator, by the way, not a generator) on my '67 Delta that I bought at the local Autozone. It's a Duralast brand, but it looks fine and works fine. They've got one for your car for about $50 plus your old core. It's a 63 amp, too, so it ought to be able to handle every electronic gadget you might plug into that cigar lighter.
http://www.autozone.com/batteries-st...19_23521_4676/
jaunty75 is offline
Old November 3rd, 2016, 08:30 AM
The part number is stamped on the flat of one of the ears. Use a wire brush.
These don't tend to not work. In all likelihood, it will work fine just as it is.
If you want to make it prettier, that's your choice. There's no reason to replace parts that work fine already, though.
If you really want to know, you can take it down to the local chain auto parts store and have them test it for free.
If you're taking it apart, check the bearings and make sure that they feel good - if not, they're cheap and easy to replace.
MDchanic is offline
Old November 3rd, 2016, 10:31 AM
farmer52's Avatar
Again, thanks for the replies. I will take it to the local parts store and have them check it. If it works fine then I will not rebuild. If it does not check out okay I will evaluate the alternatives, rebuild versus buying a reman. Thanks!
farmer52 is offline
Old November 3rd, 2016, 12:07 PM
farmer52's Avatar
Had the unit checked out at the local Advance Auto...not producing any current! So going to investigate rebuild versus reman. I would like to stay with a Delco brand but may have to settle for a "will fit". Advance/AutoZone/Summit prices are ~$50 and change with core.
farmer52 is offline
Old November 3rd, 2016, 12:20 PM
Well, that simplifies matters.
Another option, if you want to keep your car "original," is to rebuild your own.
The parts that fail (bearings, diode board, brushes) are all available fairly cheaply from NAPA, and I'm sure from on-line sources, such as RockAuto as well. You should be able to rebuild it for less than the cost of a replacement (although without some elbow grease, it won't look as shiny as a replacement).
MDchanic is offline
Old November 3rd, 2016, 12:31 PM
farmer52's Avatar
I found the part number (1102164 63 LL22 12VNF stamped on housing) but the parts book lists 1102459 (less fan and pulley). I am not concerned with cosmetics at this time considering the looks of the engine compartment.
farmer52 is offline
Old November 3rd, 2016, 12:47 PM
That's a 63A alternator.
Check RockAuto and NAPA - you should be able to get the parts to fix it quite cheaply.
MDchanic is offline
Old November 3rd, 2016, 12:52 PM
Personally I would not even screw with that one, just pickup a reman.
oldcutlass is offline
Old November 3rd, 2016, 12:54 PM
jaunty75's Avatar
That's been my thought from the start. Buy the remanufactured unit from the store, put it on in 10 minutes, and you're on to the next issue, of which it sounds like this car has many.
jaunty75 is offline
Old November 3rd, 2016, 01:16 PM
farmer52's Avatar
Originally Posted by jaunty75
...and you're on to the next issue, of which it sounds like this car has many.
Thanks for the vote of confidence. I am sure it is just the tip of the iceburg concerning issues. But for me it is the adventure (and frustration) of getting it running after sitting for 30+ years. Hey, I am a retired engineer so what do you expect?
farmer52 is offline
Old November 3rd, 2016, 01:23 PM
Fix it, replace it, whatever.
But there are a few of us nuts around who just like taking things apart, and will use whatever excuse we can to mess with stuff.
MDchanic is offline
Old November 3rd, 2016, 01:25 PM
farmer52's Avatar
I am one of those "nuts". Thank you!
farmer52 is offline
Old November 3rd, 2016, 02:24 PM
That's how I learned.
joe_padavano is online now
Old November 3rd, 2016, 06:38 PM
stellar's Avatar
That is pretty crusty. If it worked when put away 30 years ago it probably has stuck brushes. It may just need cleaned up with some new bearings and brushes. I would replace it if original look isn't a necessity. A replacement will have a different back half most of the time. I am pretty sure 1102164 is a generator number, not an alternator number. Open it up and see why it doesn't work before you replace it. It may be very simple.
stellar is offline
Old November 3rd, 2016, 07:48 PM
4 Barrels of Laughs
quaddriver's Avatar
Location: I moved to pittsburgh so I can be near Primantis
the the 63amp in my 74 started throwing the gen light, I spent many a day in my college dorm taking it apart and cleaning it until I saved up enuf for the replacement VR ($25 back then was a LOT) it got to the point out, replace, in - half hour.
quaddriver is offline
Old November 4th, 2016, 10:37 AM
farmer52's Avatar
This coming week I plan to open it up and look inside. A friend suggested converting to an internal voltage regulator while it is open. Summit Racing has a kit to convert that includes everything but the bearings (all parts needed less than $80). While it is open I might as well replace the bearings. This will definitely be a learning project.
I double checked the number on the alternator and it is 1102464. The first "4" is stamped light and I thought it was a "1". My mistake. But it still does not show in the parts book.
farmer52 is offline
Old November 4th, 2016, 10:40 AM
The internal regulator SI-family alternators use a completely different housing than does your 10DN external regulator alternator. I'm not aware of any "conversion kit". The only possible conversion is to swap the entire alternator and change the wiring to bypass the external regulator.
Old November 4th, 2016, 10:44 AM
farmer52's Avatar
What is the difference in a DN versus a SI? Learning new stuff everyday.
farmer52 is offline
Old November 4th, 2016, 10:55 AM
SI (internal) on the left, DN (external) on the right
Old November 4th, 2016, 10:57 AM
farmer52's Avatar
Joe,
My housing looks like the one on the left. See the first photo above. Did GM make a SI with external VR?
farmer52 is offline
Old November 4th, 2016, 11:00 AM
Joe,
Oh, that's the oddball 1972 "transition" alternator. Note that the terminals and hole for the connector are still different from those on the SI.
Old November 4th, 2016, 11:07 AM
farmer52's Avatar
So what does than mean? Here are the links to the kit and wire adapter.
https://www.summitracing.com/oh/parts/sum-1667
https://www.summitracing.com/oh/parts/aww-27555
The kit is for single wire but I was told to use the adapter and plug and play. Or just go with the single wire. Are they telling me the truth?
farmer52 is offline
Old November 4th, 2016, 11:12 AM
I don't know who you talked to, but the first kit is to rebuild and convert an SI alternator to a one-wire regulator. You have to start with an internal regulator alternator already. I will not work with your housing. I'll also point out that you can buy a completely rebuilt 12SI from RockAuto for not much more than that price.
The second link is for the adapter harness to bypass the external regulator if you are converting to an SI alternator. You can pay that, or you can simply make jumpers yourself for less.
Old November 4th, 2016, 11:28 AM
If you want to get parts or advice on this alternator, just contact Stellar, who posted above - He's had a starter / generator business for decades, and he can tell you exactly what the best thing to do it.
MDchanic is offline
Old November 4th, 2016, 11:39 AM
stellar's Avatar
Joe is right about it being a 1 wire kit which means you won't need the additional plugs unless looks are important. It will still be a one wire. Joe is wrong about not being able to use your rear housing. It will accept the summit parts to make it into an internal alt. I wouldn't buy the kit until I took the alt apart. If you need a stator or rotor it will cost a good bit more and they are not in the kit. If you decide to rebuild it I would go with a 3 wire reg instead of the 1 wire reg in the kit. I can supply the parts seen in the summit ad for less if you need them, with either a 1 or 3 wire reg. I can also supply a rotor or stator if needed. Good luck, but see what you need before making the purchase from summit.
stellar is offline
Old November 4th, 2016, 11:49 AM
  #31
farmer52's Avatar
Thanks all for the information. This will definitely be a learning experience.
Stellar...sending you a PM.
farmer52 is offline
Old November 4th, 2016, 01:19 PM
  #32
Really? Good to know. Thanks.
Of course, by the time you get bearings, you can still buy a complete 12SI from RockAuto for about the same money. And if you choose to go one-wire, understand the limitations of that configuration.
Old November 4th, 2016, 01:42 PM
  #33
stellar's Avatar
Joe the only difference between the transition hsg and the 10SI hsg that I am aware of is a small round post at the plug opening located oposite the plug lock opening. The 10SI has the post and the transition hsg does not. The post is a support for the internal reg plug (I don't think it is critical). The 12 si housing is thicker at that point and does not have or need the post.
Farmer, If you have doubts about doing it yourself, I can send you the rear hsg from a 10SI already assembled with the parts installed including the rear bearing less the stator or with the stator if you need it.
stellar is offline
Old November 4th, 2016, 01:55 PM
  #34
Thanks. That's good info. I have not played with the transition alternator cases.
Old November 4th, 2016, 03:32 PM
  #35
stellar's Avatar
hsgs
10SI and transition hsg
stellar is offline
Old November 4th, 2016, 04:21 PM
  #36
farmer52's Avatar
Joe,
Buying a reman unit will take the "fun and excitement" away from this learning experience.
Mark,
I will use my housing if you don't think the post will make a difference. The connecter, once plugged in, should provide some support.
Thanks again everyone for all the info.
Ken
farmer52 is offline
Old November 5th, 2016, 06:14 AM
  #37
So that transition alternator really is just a 10SI with the 10DN guts. Wow. Why would GM even bother?
Old November 5th, 2016, 06:21 AM
  #38
Could've been a supply problem. Weren't there strikes that year?
MDchanic is offline
Old November 5th, 2016, 08:04 AM
  #39
Joe,
Buying a reman unit will take the "fun and excitement" away from this learning experience. ...
Ken
From the looks of it there is plenty else to create fun and excitement left on your project. Work smart, I'm sure this opportunity will pop up in the future with a better candidate.
Old November 5th, 2016, 01:21 PM
  #40
stellar's Avatar
More like a 10SI with 10SI guts without the reg and trio. Like you describe it- a transition alt. In 72 the 10SI had already been in production for 4 years. Not used until 69, but first made in 68. Open faced alts for example. I suspect the first 10SI alts, the open faced ones were experimental and only used on a small number of models. After they proved to be reliable and a sucess they tooled to make all models with SI internal reg capability. Just my suspicions.
stellar is offline
Quick Reply: Generator Rebuild or Upgrade
