Blower motor SQUEAL!- 68 442
Old May 23rd, 2010, 10:25 AM
JBrooks's Avatar
I have a '68 442 convertible with factory A/C.
The blower motor has an awful squeal at virtually all speeds.
I am assuming the motor will need replaced.
Does anyone know how difficult this replacement is and a recommendation for a vendor to supply the motor?
Thank you.
Jim
JBrooks is offline
Old May 23rd, 2010, 05:13 PM
Thank you.
Jim
Unfortunately, this is one PITA job. You need to remove the passenger side fender, or at least the inner fender, to access the blower motor. Expect to have at least one clip nut start spinning.
I would also suggest that if you go that far, you MIGHTASWELL replace the heater core at the same time, since it also requires the fender to come off (to access the bottom bolt on the box).
joe_padavano is offline
Old May 23rd, 2010, 06:43 PM
bgoble's Avatar
Joe... is the same true for a 72 Cutlass?
bgoble is offline
Old May 23rd, 2010, 07:48 PM
JBrooks's Avatar
Thank you, Joe.
I genuinely appreciate your response, although I wish the message were a bit better.
Thanks again.
Jim
JBrooks is offline
Old May 23rd, 2010, 08:43 PM
Yup, same PITA location. Green wire feed. Bolted in just behind the passenger side wheel cover. I'm doing the same thing Joe recommended; changing the heater core at the same time when I do mine.
Allan R is offline
Old May 26th, 2010, 06:50 PM
Kace's Avatar
Hey, Have same car, I have a purple wire going nowhere near fender on a/c side. Any idea what it's for?
Kace is offline
Old May 26th, 2010, 07:13 PM
Best guess
Sounds like it may be part of the hi blower relay?
DSC01889.jpg?t=1274926378
Allan R is offline
Old May 26th, 2010, 08:03 PM
bmort's Avatar
purple wire
mine plugs into the little "pig tail" condenser right above the purple wire on my tire.
bmort is offline
Old May 27th, 2010, 02:59 AM
Yellowstatue's Avatar
To prevent the clip nut from spinning, put a 1/2 inch box wrench (six point) on the nut first and if your arms are short on one end then have a helper operate the ratchet whilst you hold the wrench firmly to prevent spinning... of course this is on an original '68 clip nut...
Yellowstatue is offline
JuzCallMeDee
March 26th, 2013 02:25 PM
Johnny Cage
February 28th, 2013 02:28 AM
deltaboy
February 6th, 2013 01:01 PM
kplange
January 7th, 2012 07:11 PM
hunter
November 18th, 2011 11:45 AM
Quick Reply: Blower motor SQUEAL!- 68 442
