j2
Old October 4th, 2008, 10:41 PM
d-666's Avatar
j2
it may sound stupid(im new to olds,im a buick guy)but what does j2 means on my 324 4v air cleaner?
tanks
d-666 is offline
Old October 4th, 2008, 10:55 PM
citcapp's Avatar
It means you have a decal that someone put on your air cleaner. The J2 option (tri-power) was not available until 1957. It was also available in 1958. Then it was discontinued. I don't think the 324 shares the same architecture as the 371 so I don't believe the tripower could have been retro-fitted. If it has tri-power it would be an after market Intake with after market carbs
citcapp is offline
Old October 5th, 2008, 07:24 AM
He said it was a 4V (which I assume means 4 bbl) air cleaner. Definitely NOT a J2.
joe_padavano is offline
Old October 5th, 2008, 09:13 AM
d-666's Avatar
tanks,i will remove that sticker..
d-666 is offline
Old October 5th, 2008, 03:26 PM
Junior Member
88 coupe's Avatar
........ J2 option (tri-power) ........
J2 = The name Olds used to market its Three 2-Barrel carb option.
Tri-Power = The name Pontiac used to market its Three 2-Barrel option. It was never used by any other manufacturer.
........ I don't think the 324 shares the same architecture ........
Same engine, except for the increased bore and stroke, and the ¼" difference in deck height. The comparison is very similar to that of a 330 vs a 425.
........ I don't believe the tripower could have been retro-fitted ........
Hard to "retrofit" a Pontiac manifold on an Olds engine.
J-2 manifold fits '57-'58 only, because of the differences in deck heights.
Norm
88 coupe is offline
