Frozen heat rizer?
Old February 17th, 2009, 06:13 PM
johnfharding's Avatar
Frozen heat rizer?
Upon disassembly of the remainder of the engine bay I found that the heat rizer was frozen mostly closed with a maximum of maybe a quarter inch open. I was thinking this would cause extreme back pressure or reroute the exhaust through the intake manifold and out the other side center exhaust port.
What is your take on this and would this cause a fair amount of performance loss as I would expect?
johnfharding is offline
Old February 18th, 2009, 04:44 AM
The 394 I had in my 64 98 had the same problem. I knocked out the valve and cut off the external bimetallic spring that activates the heat riser. This will definitely make your car run worse.
Olds64 is offline
Old February 18th, 2009, 08:56 PM
Junior Member
88 coupe's Avatar
Originally Posted by johnfharding
........ would this cause a fair amount of performance loss as I would expect? ........
Yes, it would.
It is only used to help heat the carb/choke during warm up. In warmer climates, it has been common practice to wire them open, or to remove them completely.
Norm
88 coupe is offline
Old February 18th, 2009, 10:02 PM
hmm
I will sure be interested to know what this thing will run like when I get done with it.
I would think with the issues I have found and the freshened up motor it should run a substantial amount better than before.
Old February 19th, 2009, 01:39 AM
Registered
Bluevista's Avatar
The car should run a lot better. I had a wagon that happened to and the thing was a dog until it was diagnosed. Everybody wired those things open as mentioned or welded or brazed the shaft to keep it permanent. A manual choke was sometimes added because without the heat riser it wouldn't heat up the choke stove fast enough on some cars.
Bluevista is offline
Miles71
October 16th, 2013 01:10 PM
Flye
April 4th, 2013 06:29 PM
sam196370
September 18th, 2012 10:00 AM
turbobill
December 30th, 2011 11:15 AM
rroth01
April 23rd, 2008 07:03 PM
Quick Reply: Frozen heat rizer?
