95 olds dies intermittently at high speed
olds that dies
It just dies on hwy twice in last few days,restarts after a couple of tries,changed fuel filter this am.works fine under full throttle this am.also ran fine both times on hwy after restart,
Diagnosis plug should be far under steering column for that car.Sounds like you have a intermittent sensor issue,ive been there,you need to go to a top notch garage that has diagnosis equipment that scans cycle after cycle for every sensor (reads like a ekg machine at a hospital )those hand held scanners that reads codes are nooooooo match for an issue like that on that car trust me,,good luck
smcurro
Paint
January 29th, 2012 02:31 PM
emarkay
November 14th, 2005 09:13 PM
emarkay
December 8th, 2004 08:23 AM
