1962 dynamic 88 transmission
Old March 11th, 2015, 05:44 PM
eddieunderground's Avatar
My transmission went out in my Dynamic. I been calling around. It's gonna be a lot of money to rebuild. If they can even find the parts. I heard it would be cheaper to get another type and install. What is another alternative? I heard I could get a 200R transmission with overdrive and it would bolt right on. What other beefier transmission setups can I do? And what will I need to make it work?
eddieunderground is offline
Old March 11th, 2015, 06:21 PM
Phantom Phixer
Charlie Jones's Avatar
Whomever told you that a TH 200 4R trans would bolt in was wrong.
However it can be done, and Tony Ross is the one to do it.
https://rossracingengines.oursafeser...early-catalog/
It's probably best to call him at 330-544-4466
Probably won't be too much more money than a rebuild of the "slimjim" and a helluva lot better. These "slimjim " trannies are the main reason that 61 to 64 Oldsmobiles are so rare.
Here is a thread on the conversion;
https://classicoldsmobile.com/forums...-slim-jim.html
Charlie Jones is offline
Old March 12th, 2015, 03:31 AM
Oldsdruid
rocketraider's Avatar
The parts are available, finding someone to do it right is going to be the issue. Most shops don't want to hear "slim jim".
Ross would be my first choice for a modern transmission conversion for these cars but Tanson Enterprises http://www.forwhatyouneed.com/tansonp1.html is in Sacramento and might be easier for you.
rocketraider is offline
Old March 24th, 2015, 12:08 PM
Kahuna's Avatar
If you have a reputable trans rebuilder in mind, you can perhaps save some time, money and trouble by buying the complete rebuild kit yourself. Here are a couple of sources:
http://www.autotran.us/rhmkits1.html
http://www.fatsco.com/products.htm
Good Luck!
Kahuna is offline
6inarow
August 27th, 2019 11:22 AM
eddieunderground
September 4th, 2015 02:47 PM
My62F85
July 31st, 2014 09:44 AM
tiparosa
March 4th, 2007 07:26 PM
D. Yaros
November 19th, 2006 02:19 PM
Quick Reply: 1962 dynamic 88 transmission
