Best / Easiest Way to Change Carrier Bearings
Old September 20th, 2014, 12:44 PM
RandyS's Avatar
What is the best and or easiest way to remove the old carrier bearings and install new ones. 66 10 bolt 8.2". I don't have access to a press unless I visit a pro.
RandyS is offline
Old September 20th, 2014, 01:37 PM
Stevec's Avatar
Have them pressed off and on you don't want to damage the carrier.
Stevec is offline
Old September 20th, 2014, 03:04 PM
techg8's Avatar
cutting wheel takes the cage off, the bearings spill out.
cutitng wheel cuts as deep a groove as you can into the bearing race without cutting the carrier case.
a fat chisel in the groove and a hammer will split/crack the race and it can be pried off.
for installation you can use the old race and a flat piece of stock to hammer the new bearing on.
OR freeze the carrier and heat the new bearing so it will slip on.
I dont recommend any of this but it has worked for me in a pinch.
Best way obviously is the right way...bearing separators and a press.
techg8 is offline
Old September 20th, 2014, 03:10 PM
RandyS's Avatar
Yeah, I figured the press was the best way. Just didn't want to have to wait till Monday to find a shop open...........
Thanks.
RandyS is offline
Old September 25th, 2014, 11:57 AM
monzaz's Avatar
Wait
WAIT.... Your going to regret it. Jim
monzaz is offline
Old September 25th, 2014, 12:12 PM
Professur's Avatar
Professur is offline
Old September 25th, 2014, 02:32 PM
RandyS's Avatar
New bearings pressed Monday morning. Had to plastic hammer the carrier back in to the saddle. Backlash @ 008, pattern looks much better. Thanks for the advice!
RandyS is offline
Old October 1st, 2014, 07:45 PM
monzaz's Avatar
Plastic hammer?
Do you mean DEAD BLOW? JIm
monzaz is offline
Old October 1st, 2014, 09:25 PM
RandyS's Avatar
Plastic Mallet so as to not cause any damage..........
RandyS is offline
Old October 3rd, 2014, 04:21 AM
monzaz's Avatar
Yes... As stated pretty sure that is a DEAD BLOW HAMMER. lol Jim
monzaz is offline
1Fastolds
Ninety-Eight
June 9th, 2014 09:12 PM
Radius
April 21st, 2013 10:51 AM
ATrain1
Non-Olds Engines
June 29th, 2012 12:58 PM
oldzy
Drivetrain/Differentials
September 14th, 2010 05:40 AM
mattnsac
June 3rd, 2007 10:25 PM
Quick Reply: Best / Easiest Way to Change Carrier Bearings
