1963 F85 driveshaft center support
I have a '63 Cutlass/F85 and need the driveshaft center support. I have the bracket, and the bearing- but the rubber between the bearing and the bracket is starting to deteriorate. There is a place in Ca. that re-vulcanizes (Doctor Damper), but I'd like to find a complete bracket/rubber/bearing combination NOS or replacement part before I go that route. Any suggestions? Thanks.
Support:
Driveshaft Support 1962-63 Buick Special
[BS623-3] $48.75
1962-1963 Buick Special, Skylark
Propeller (Drive) Shaft Center Bearing Support
New manufacture
Be sure to replace the bearing too!!
Link also:
http://www.oldbuickparts.com/catalog...al-p-2948.html
Good luck,
Ken
[BS623-3] $48.75
New manufacture
Link also:
Good luck,
Ken
Thank You, I found that On the website.
Driveshaft Support 1962-63 Olds F-85
[BS623-O]
1962 Oldsmobile F-85 (2nd type)
1963 Oldsmobile F-85
http://www.oldbuickparts.com/catalog...5-p-26826.html
Xavier
[BS623-O]
Xavier
jensenracing77
January 25th, 2018 04:16 PM
62 Cutlass Convert
August 12th, 2015 11:35 AM
