1963 F85 driveshaft center support
Old June 26th, 2011 | 12:58 PM
Jetfire63's Avatar
I have a '63 Cutlass/F85 and need the driveshaft center support. I have the bracket, and the bearing- but the rubber between the bearing and the bracket is starting to deteriorate. There is a place in Ca. that re-vulcanizes (Doctor Damper), but I'd like to find a complete bracket/rubber/bearing combination NOS or replacement part before I go that route. Any suggestions? Thanks.
Old June 27th, 2011 | 07:59 AM
citcapp's Avatar
Try Fusick's
http://www.fusick.com/catfile/Catalo...yout%201_3.pdf
Old November 17th, 2013 | 12:41 PM
Xavier_rgc's Avatar
Hi Jetfire63,
I know it's a long time but I have now the same problem as you. I asked Fusick's, they answered me they don't have that parts. Did you find a solution ?
Old November 21st, 2013 | 08:16 AM
1k442's Avatar
Support:
Driveshaft Support 1962-63 Buick Special
[BS623-3] $48.75
1962-1963 Buick Special, Skylark
Propeller (Drive) Shaft Center Bearing Support
New manufacture
Be sure to replace the bearing too!!
Link also:
http://www.oldbuickparts.com/catalog...al-p-2948.html
Good luck,
Ken
Old November 22nd, 2013 | 05:45 AM
Xavier_rgc's Avatar
Thanks' Ken,
Does that fit directly or will I have some modifications ?
I've got the bearing. It's a Timken X908CC
Xavier
(because I'm in France and it will be difficult to return a wrong part)
Old November 22nd, 2013 | 07:26 AM
1k442's Avatar
It should fit like the original. I have not used one but should work.
Good luck,
Ken
Old November 22nd, 2013 | 08:01 AM
Xavier_rgc's Avatar
Thank You, I found that On the website.
Driveshaft Support 1962-63 Olds F-85
[BS623-O]
1962 Oldsmobile F-85 (2nd type)
1963 Oldsmobile F-85
http://www.oldbuickparts.com/catalog...5-p-26826.html
Xavier
jensenracing77
January 25th, 2018 04:16 PM
62 Cutlass Convert
August 12th, 2015 11:35 AM
papaya
Drivetrain/Differentials
September 5th, 2012 10:56 AM
trackz man
March 9th, 2011 01:35 PM
nelsontj
March 15th, 2010 08:41 PM
Quick Reply: 1963 F85 driveshaft center support
