Pinion companion flange '56 er
Old August 1st, 2023, 11:30 AM
D.Janssen's Avatar
Hello everyone, i need some help here. I want to replace the pinion oil seal of the differential from my 1956 Oldsmobile cause of a leak there.
I disconnected the shaft and now i want to loosen the nut of the companion flange. Now there i'm stuck, the nut won't move a single inch. The car is rised up with the back wheel on some woodbocks so the flange is not be able turn. I used al my power and a extended wrench but there is no movement in the nut. I'm turning it counter the clock is that correct?
Could you help me out here please?
I've noticed there are some gaps in the nut, i think there used for extra thighting.
D.Janssen is offline
Old August 1st, 2023, 11:40 AM
D.Janssen's Avatar
Old August 1st, 2023, 11:41 AM
D.Janssen's Avatar
Old August 1st, 2023, 06:14 PM
monzaz's Avatar
You need an impact - HD electric or AIR is usually the best. Sorry gonna need to borrow or spend some money on this one.
monzaz is offline
Old August 1st, 2023, 07:22 PM
Sugar Bear's Avatar
Precisely count the threads exposed and match mark the nut flange position before disassembly. The goal is to put the nut back EXACTLY where it is without over tightening. I agree you'll need a strong impact to remove the nut.
Sugar Bear is offline
Old August 2nd, 2023, 08:39 AM
D.Janssen's Avatar
Thanks for the reply guys, i used the impact wrench and finally it came loose 😀. Now i can replacement the oil seal. Thanks
Old August 2nd, 2023, 09:56 AM
monzaz's Avatar
Make sure you use lock tight and do not use the GUN to re-tighten...MAKE it as tight as you can by hand...You will not re-crush the sleeve... you will need a 2+ foot bar to make that happen. IF by chance the nut does make the the pinion tight...SOMEthing was wrong from the beginning. ?? IF everything feels good no in out play and smooth spin... stake that nut with a pointed steel punch in the tapper of the pinion nut enough to mangle the nut into the thread .... DO NOT go nuts one good strike should do it. THAT will keep the nut from backing off when driving . Good luck to you.
Jim
JD Race
monzaz is offline
JOHNNYOLDS442
September 30th, 2020 08:53 AM
matefis
Drivetrain/Differentials
July 18th, 2020 03:57 PM
1kool88
October 28th, 2014 08:40 PM
drewt
December 1st, 2009 07:28 AM
jensenracing77
April 16th, 2009 04:59 AM
Quick Reply: Pinion companion flange '56 er
