1971 Cutlass B – 350 – factory standard rear axle ratio?
Old December 16th, 2016, 02:01 AM
trevor1400's Avatar
Sorry for my question if I haveoverlocked the answer in the forum.
Do you know which standard rear axleratio for a 1971 Cutlass Base – 350 – TH350 was delivered from the factory?
Thank you and
regards
Trevor
trevor1400 is offline
Old December 16th, 2016, 06:18 AM
monzaz's Avatar
fatory ratio
could really be any thing...
likely with that stock combo a 2.73 or 2.56 will be most common.
monzaz is offline
Old December 16th, 2016, 06:27 AM
My car came with 2.56.
Fun71 is offline
Old December 16th, 2016, 07:33 AM
The Salesman's SPECS booklet tells you EXACTLY what the standard axles were for each drivetrain combination, as well as the available options.
For the Cutlass line in 1971, the standard axle ratio with TH350 and 350 2bbl (RPO L65 motor) was 2.56:1. With the L74 350 4bbl motor it was 2.73:1. Note that in the Cutlass Supreme line, standard axle was 2.56:1 with either of those motors.
joe_padavano is online now
Old December 19th, 2016, 09:24 AM
monzaz's Avatar
details
Yep, That is what is should be...But you know how the factory lines went... KEEP THE LINE MOVING. You never know unless you dig into the rear physically.
Jim
J D
monzaz is offline
Old December 27th, 2016, 12:09 PM
trevor1400's Avatar
Thank you for all the answers.
Now it's clear, my Cutlass has 2,56:1....
Best
Trevor
twilightblue28A
Drivetrain/Differentials
April 9th, 2016 07:13 AM
halfmoontrail
July 1st, 2011 09:08 AM
HouTXCutlass
Suspension & Handling
January 13th, 2010 07:41 AM
mutzi
July 16th, 2009 05:04 AM
Quick Reply: 1971 Cutlass B – 350 – factory standard rear axle ratio?
