1965 442 cutlass pinnon gear
Old July 15th, 2017, 10:54 AM
olds3031's Avatar
, I noticed on the pinnon gear I removed a rubber o ring in the grove behind the splines, the gear set I am installing 390 has all splines no grove ,it is aftermarket .i do not ever remember seeing a rubber o ring on any olds pinnon, 323 gears is what Am removing, I looked in my 1965 service manual at the view of the ring gear installed , does not show a o ring, any idea what it is? My car is 1965 442 , factory 323 gears I am taking out.
olds3031 is offline
Old July 15th, 2017, 11:14 AM
olds3031's Avatar
olds3031 is offline
Old July 30th, 2017, 08:20 AM
monzaz's Avatar
That was to prevent pinion spline oil seepage... we just use liquid Teflon now...you can use natural gas pipe thread Teflon...
Just apply a small amount inside the yoke splines 360 degree and stay away from the pinion seal with the teflon.... you do not need much...
good luck, Jim Mitschke
J D Race
monzaz is offline
O-dawg
November 3rd, 2016 06:07 AM
Cman7713
Drivetrain/Differentials
March 20th, 2016 08:11 AM
HonestDave
November 21st, 2013 08:21 PM
HonestDave
May 30th, 2013 12:57 PM
drjr56
September 9th, 2012 08:05 PM
Quick Reply: 1965 442 cutlass pinnon gear
