1964 jetstar rear end identification
I want to change the gears in the rear end. Looking to identify which housing i have. 1964 Jetstar 88 2 door hardtop 330. I know i currently have 3:08 gears.
Where do i start.
Where do i start.
Your 1964 J88 uses a BOP 8.2" rear axle. While the housing is unique to the 1964 J88, the center section and gears interchange with those used on the Cutlass and other A-body cars with the 8.2" axle.
Im in Canada so pricing on the parts from U.S was just too much after i found a posi unit on amazon.ca.
I brought the posi unit to a shop, and hes having a hard time identifying stuff. Hes not sure i have the right unit. I purchased the ydggm8.2bop-3-28-1.
This is a picture from last year when i changed the gasket out. So the unit I have is a 8.2 BOP for sure?
Is there numbers stamped on the housing anywhere.
BOP wrong posi unit
BOP 8.2
Buick 1964-1967
2 series is 2.56-2.78
3 series is 2.93 3.08 3.23 ratios
4 series is 3.36 3.55 3.90 4.33 etc.
Sooo your bop Yukon posi is for 3.36 - 4.33 and beyond gears. It will not work correctly with your 3.08 ratio
You need the 114 or 099 Auburn unit.
Jim
JD Race
Buick 1964-1967
Jim
JD Race
parts
Sometimes it better to pay a little more to get the correct stuff the first time... ?? Maybe?
For a CHEVY rear it is 3.08 -4.56 ratios. ydggm8.2-3-28-1
ydggm8.2bop-3-28-1 is for 3.36 - 4.33 and beyond.
Jim
JD
Jim
JD
Love1955oldsmobile
September 15th, 2020 04:32 PM
