72 cutlass rear bumper grommet installation
Old March 17th, 2017, 11:17 AM
72cutlassconvertible's Avatar
these are the grommets behind the license plate. They seem too large for the slotted holes, I tried using Dawn to lubricate, but don't want to tear them. Any idea on how to install? They do NOT have a hole in the center of the grommet.
72cutlassconvertible is offline
Old March 26th, 2017, 12:09 PM
Chumley's Avatar
Shouldn't be difficult. Are these what you are talking about? They are actually called license plate bumpers. Usually you do need some type of lubricant to make them install easier, but might you possibly have the wrong ones for your bumper?
Chumley is offline
Old March 26th, 2017, 02:02 PM
I find it easier to pull them through from the backside then pushing from the front. When you push, the rubber expands against the opening in the bumper and makes it almost impossible to get in, but whey you pull the rubber stretches, making the insert portion thinner and it slips in easier. When you pull it from the backside, also push from the front to help it along.
Fun71 is offline
Old March 27th, 2017, 09:50 AM
Chumley's Avatar
Great tip, I'll remember that next time it comes up
Chumley is offline
Old April 5th, 2017, 09:04 AM
Lightbulb rear license plate grommet
Dude, I can't even come close to pulling them from the backside because the bumpers on the car & there is very little room to access it. Sooo, I just shaved a little off of each side of those tabs of the grommet & viola it worked fine. Nice & tight too!. Thank you for tip though.
Old April 5th, 2017, 06:14 PM
Chumley's Avatar
After market parts are often less than perfect fit. Glad you got them installed
Chumley is offline
stlbluesbrother
February 14th, 2015 10:25 PM
75hurstoldsW-30
August 22nd, 2014 04:54 PM
ProfitOfDoom
June 16th, 2014 05:53 AM
1969camaross350
April 17th, 2013 07:50 AM
csouth
June 11th, 2009 06:57 AM
Quick Reply: 72 cutlass rear bumper grommet installation
