Need serious help gettin started
I JUST GOT RIPPED ME OFF FOR $100 AND READY TO BUST DUDE HEAD IF I SEE HIM BUT MOR TO THE MATTER I HAVE A 72 GOLD/RUST 4 DR CUTLASS IM TRYIN TO FLIP TO SHOW CAR. FIRST WANT TO GET STARTED, 2) POP TRUNK WIT NO KEY, 3) BODY WORK TRUNK AND CAR, 4) PUT 8 10'S IN TRUNK, 5) LIFT CAR TO FIT 26"S, FROM THERE I'LL BE GUD BUT NEED TO START SUMWHERE AND DO IT MYSELF CAUSE IMA HURT 1 OF THESE REPAIR GUYS TRYNNA GET OVA ON ME CAUSE IM 20
So you have a 72 4dr that you want to turn into a show car. You want a remote lock for the trunk and have a speaker box built to go inside. Then have it lifted for 26 inch rims.
Your having a problem finding a trust worth body man to do the work.
Maybe telling your location, someone maybe able to give you a name of some one good.
Yo dude, mos here R olden an yous got to get wit the oldschool rap. as fur wit we see, u takin shete an weese need to follo wat u sayin, u no wit i'm sayin? my momma din raise no dummies but what the hell u talkin bout Willis? we lookin to help but we need to no wat u sayin.
http://www.youtube.com/watch?v=0bhTxvzrUFo
sb
You, sir are a paragon of goodwill and an example of tolerance to us all. Not only that, but you speak jive. I am impressed.
sb
sb
I've always liked that movie. I am serious....and don't call me Shirley.
Olds425, and 70 cutlass s, Thanks for keeping with the forum etiquette for I see a lot of new users from Australia, Switzerland, Canada etc. that aren't mocked for their lack of the use of proper english. Let's all understand that we do what we want to do with our cars so when someone else wants to do something that we may or may not do to our own that it is THEIR car. They don't complain about us keeping ours all original, or putting on a set of SSI, Crager's, or changing the paint color so lets not mock or tease someone for what they want to do with THEIR car.
CEOJOE,
When you use all caps on a forum board it is not only considered shouting but it is also harder for some of the viewers to see. 1) You mentioned getting the car to start, are you getting adequate power from the battery? Fuel flowing from tank? Does the car turn over but won't crank? Be more descriptive of the problems you are experiencing and post your location a member may live nearby and can come assist you.
2) http://www.summitracing.com/parts/ELI-PT200/
3) Again if you post your location I am sure some of the members here will be able to help you find a good bodyshop.
4) http://cgi.ebay.com/4-FOUR-HOLE-10-S...item414fd57cd2
5) http://universalcarlifts.com/product...roducts_id=229
P.S. Please don't go and bust someone's head over a $100 that might land you in jail not only owing a fine quite a bit more than $100, but also locked up! Then you won't be able to work on your Olds
CEOJOE,
Do you really think this is a person of foreign origin trying to convey a thought in a second language? Really?
If it is, I apologize. But I will say this, if it is a person from another country carrying on the old car hobby, I will eat my hat.
My guess: this person is a product of our public school system and the texting revolution of our times and he thinks this is the proper way to communicate via a keyboard.
I, for one, would not frequent a board covered with this sort of "communication." More suited to a Jr. High yearbook.
Do you not find it hard to decipher the original post?
sb
Say What?
What's proper English?
Who makes fun?
An Oldsomobile is what it's called in Italy?
IMO we are very good to foreign members here and they never complain at all, in fact they all praise this site for the help and patience when they have trouble communicating. We are also very tolerant of all types of all cars and what is done to them... as long as they're Oldsmobiles. Just don't put a chebby engine in it and your golden, pun intended.
Those foreign guys are learned by there teacher a second language and knows how to talks and types it gooder than we does.
Pop trunk with no key?
Have "The Fonz" smack it once and it will open right up.
If it is no trunk key the glove box is the same, can take the lock tumbler to a locksmith and have a new key cut from that one. Just take the whole door, or car. A locksmith could open the trunk in a minute too.
Take out the back seat and if you can see the back of the latch you turn the piece where the shaft comes through or just unbolt the catch or latch. Some cars you can't get in there well so you take a broomstick and cram it over where the lock extendo piece goes through the back of the latch hard and turn at the same time. You can also use a long socket extension and unscrew those bolts.
Who makes fun?
In my experience, it's not the non-Americans who have a problem with proper English.
CEOJOE,
CEOJOE,
I can't say for sure but I would guess that this is some one that is trying to stir up the people on the board for fun. Just my opinion, but they haven't been back to post. On a side note, I am living in Japan and I have talked to Japanese Nationals that have a better command of the English language.
How did you get ripped off for $100? That doesn't sound too bad.
26's fit on a Cutlass? Wow, that'll make a statement!
8 10's in the trunk? Do you want to blow the rear window out? yikes, guess I'm getting old before 40.
Well, post any reasonable questions here, I'm sure one of us can help.
Ok ok let me start by saying thanks for people that helped and ones that didn't was heat when i started post but i do need help. 1st I have a 72 4dr cutlass wit 72g miles on it that carb dont work but can move. 2nd i got rip off for a hei distributor and now have a proper 1 in black. 3rd and most important i want to max out wit car wit 24's body and paint, guts, and sounds but if i dont get car started first im f#@ked. My engine as told is not locked but the person who ripped me off never gave me info bout what position distributor was in. 4th my trunk is locked and i have no key. I am goin to try glove box trick but if dont work what should i do. Need help with everything cause this my 1st old school car "born in 89 and had 7 cars from Lincolns, Cadillac, and just sold 94 t-top firebird" in the 757 area of Va
Location: Issaquah, Washington ( 15 miles east of Seattle )
Wow ! Sounds like you have a ton of issues with this car. You sound a little angry as well, like someone did you wrong. I would ask one question at a time to start out with because if what you just said was a picture, it would be of someone hitting a hornets nest with a stick. There's alot of buzzing going on and I'm confused....
Maybe load a photo so everyone can see what you have to work with.
1) If your car can drive around the block but doesn't run too well then I suggest you rebuild the carburetor and do a tune up. For less than $100 in parts (if you do the labor yourself) you can completely tune up your Olds.
2) If you have an HEI distributor you can always take it to the auto parts store and make sure the module is still good. If it is then all you have to do is put it in the engine and wire up the spark plug wires.
3) If you want to paint the car and put rims on it then you might want to find a local shop near you that specializes in rims/paint. Depending on what type of paint you want you can either pay someone $10,000 to put a House of Kolor paint job on it or you can pay $1500 to sand it your self, prep it and drop it off at Macco. The problem with big rims is going to be finding the proper wheel size and tire size without going too big.
3a) If the distributor isn't in the car then put your finger over #1 spark plug hole and have a buddy kick over the engine with the starter. Once your finger is blown off the spark plug hole by compression that will be TDC on #1. You should also see the timing mark on the harmonic balancer. Just install the distributor so it is pointing at the #1 cylinder. Then wire your spark plug wires accordingly.
4) If your trunk is locked and you don't have the key you can sometimes remove the back seat and pop open the lock from the back with a really long screw driver.
Does the car run or not?
Do you have any sort of manual for the car? Some very basic things are (seemingly) throwing you for a loop. If you can find you can find TDC for #1, you can stab the distributor and figure out where the wires need to go....1-8-4-3-6-5-7-2 is the firing order.
Is the carb a 2bbl or 4bbl? Maybe I missed that somewhere. Either way, as much as I hate remanned carbs, that might be your best bet. Figure right around $200.
You've already gotten several good tips on getting the trunk open.
sb
#31
Usually, the spark plugs come pre-gapped from the parts store. If not then just ask them what the spark plug gap should be. Sorry I can't remember what it is off the top of my head.
BTW, looks like a good project!
#32
Never trust the factory gaps. That 20-year old behind the counter probably dropped them all over the place and gave you the ol' zero gap! (Just jokin' about the 20-year old stuff CEO, don't come after me!)
My Motors manual says (for a 1972 2bbl 350):
Plug gap: .040" (40 thousandths)
Point gap: .016" (16 thousandths, or dwell = 30 degrees if you have a meter)
Timing: 8 degrees @ 1100 RPM.
Good Luck!
Bob
Good Luck!
Bob
#34
got car started did my own tune up but gotta do oil change and radiator flush. Had no brakes @ first but bleed brakes and found out front wheels was locked but friend helped me and it was just tight and rusted. is there anything i can simply do to make run faster?....or easiest and cheapest way to lift 5 inches
#35
Good job on getting the car started. As far as making it go faster are you currently running a 2 barrel carb or a 4 barrel? Do you know if it has a performance cam in it or the stock cam? What rear end gears are you running? Stock points or an Hei system? Theses things can be changed to give you more power.
#36
The easiest swap would be to go to a 4 barrel carburetor (I see in the pic you have a 2 barrel). You can usually find stock parts for this swap fairly cheaply.
If you want to raise your suspension for big wheels I suggest going to a shop that specializes in this work. My guess would be that you would have to put a lift kit on your car (like the truck guys do).
BTW, here is an excellent website for swapping tires and rims:
http://www.rimsntires.com/rt_specs.jsp
Just put your stock tire size on the left side (you probably have a 7 inch rim with 0 offset). Then tinker with the tire size unitl you find a bigger rim and tire with the same outside dimensions.
#37
I am the second owner of 72 4 dr cutlass an old lady from NC owneed it b4 me so my car is all stock but the HEI Distributor but it get but i want to be able to fly 80 on 24's or 26" rims. but first want to repair fenders, front & back window, por 15 everything i can and get body to prime and add lambo doors on front doors
#39
The easy way to get your car to black primer is to just sand the whole car and buy yourself some rattle cans of black primer and have at it.
That is NOT the right way to do it though if you want it to look decent. There is no easy way to do body and paint work. It takes a lot of patience, time and the proper tools.
Ron
Ron
#40
Lambo doors. So FAIL Lamborghini doesn't even use them anymore!!
