How do you get to those plugs?
Old September 30th, 2006, 09:47 AM
sbs4332's Avatar
I tried to change the spark plugs on my 1988 Cutlass 2.8 liter, but cant get to the back side plugs. Anybody have the same issues, and if so, how did you get these plugs out? Thanks for any help.
sbs4332 is offline
Old November 22nd, 2006, 03:46 PM
cutroc350's Avatar
To get to the rear plugs dissconect one end of each front engine mount after you make sure you are parked on a level serface. After you remove the mounts you can then tilt the engine foward enough to reach the plugs.
cutroc350 is offline
Old November 23rd, 2006, 05:58 PM
Chumley's Avatar
Boy, and I thought removing the front wheels on my '70 SX to access the rear plugs from over the A-arms was a pain in the butt! Don't know if an '88 would allow you to do that.
Chumley
Chumley is offline
Old February 24th, 2008, 05:50 PM
Redog's Avatar
Gotta climb under the hood and look down the back of the engine.
Works on the Alero
Redog is offline
Old February 28th, 2008, 02:19 PM
arocars's Avatar
You could also try to access the plugs from underneath the car.
arocars is offline
Old February 28th, 2008, 02:22 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
R.I.P.
This thread
2006
J-(Chicago) is offline
Old February 28th, 2008, 02:25 PM
The_Jeremiah's Avatar
LOL too bad i didnt see this before. because thats why they put the engine mount right on top. there is even a big loop attached to the engine. all that is so you can unbolt the motor and attach an engine lift to it. it will rotate pretty far.
The_Jeremiah is offline
DewChugr
July 20th, 2015 07:09 PM
bob p
April 10th, 2015 01:55 PM
skryla
November 3rd, 2011 08:39 PM
jaunty75
August 5th, 2009 06:05 PM
vista461
July 25th, 2009 06:01 PM
Quick Reply: How do you get to those plugs?
