edelbrock manifold and carburetor?
ok i have a stock 72 cutlass..with a 2bbl carb. I was gonna buy edelbrock manifold 3711.. but i was readin on jegs.com that i can buy that manifold but any edelbrock acrd would not fit on it... does anyone know if this is true?? pls help.. i wanna put a 4bbl edelbrock carb
The manafold is for use with a quadrajet BUt you can buy an adaptor to adapt the edelbrock carb to the e3711. The adaptor you need is quadrajet barrel size on one side and 4 even butterfly sizes on the other side. It allows the carb to be raised so the carb linkage does not hit the manafold. OR just buy a rebuilt Q/J for an oldsmobile and out that on and go.
I bought the 7111 mani for 2 reasons
to avoid this problem, and because I wanted to have a bit more power. The 3711 mani is the same as a plain old Olds mani, just a lot lighter
Quadrajets are great carburetors. They are also simple to rebuild. If you want to learn carburetors a quadrajet is a good place to start. I also like Edelbrock carbs. They are a bit more pricey than a rebuilt Quadrajet but they do look pretty sharp. There is nothing better than kicking in the secondaries of a Quadrajet though.
JUst an FYI. I was told by Edelbrock that the Edelbrock 1406 would not bolt on the 3711 because of the EGR. I did find out that edelbrock has corrected this by releasing the 2711 manifold that will work with edelbrock carbs. ($300 At Summit Racing). 2711 has no EGR provisions.I just got one today and will be slapping that sucker on next weekend.
vette442
September 6th, 2013 04:57 AM
yeahbuddy
June 1st, 2010 05:38 AM
