bolt missing on rear hub assembly
Old August 25th, 2011, 10:33 PM
nj_cutlass72's Avatar
so when I bought the car, I noticed that one of the lug nuts was missing and this bothered me.
I figured I'll take of this, so it's the rear wheel on passenger side and I took the wheel off to have a look.
Two questions, to mount a new bolt do I have to take off everything behind it for clearance? or is it a easy slip in, one friend mentioned that I have to bang it in with a hammer. Please see pics, also does a local store have this or I need to go online? thanks in advance...
nj_cutlass72 is online now
Old August 25th, 2011, 10:45 PM
Run to Rund's Avatar
If the axle hole is undamaged and a new stud doesn't just fall into place, you can use a lug nut and grease the threads to pull the stud into place. If the hole is just a bit iffy, use some Loctite. If the stud falls into place, you need a stud with larger diameter splined area that will fit tight. Parts houses carry the studs.
Run to Rund is offline
Old August 25th, 2011, 11:36 PM
thanks, will give it a try and let you know.
Old August 26th, 2011, 04:12 AM
69442C's Avatar
Obtain the correct stud, install the stud from the back side, place a washer and a lug nut (installed backwards so flat end is against the washer) and tighten it until the stud is fully seated. If you have an impact wrench, that will make the install go very quickly. I would not use any grease on the splines. If the hole in the axle is damaged, you'll need to get another axle.
69442C is offline
Old August 27th, 2011, 08:21 PM
using washers to pull the stud to flush was a great idea, all done - thx
marxjunk
February 24th, 2015 06:45 PM
CUT-N-UP
November 6th, 2013 07:10 PM
bulldog
September 27th, 2010 05:03 AM
oldsonharmont
Suspension & Handling
December 23rd, 2009 10:59 PM
elcaminodave
May 26th, 2009 02:49 PM
Quick Reply: bolt missing on rear hub assembly
