350 rocket help
I just realized you're the same one on you tube that asked about my 350. You just missed it. I ended up damn near giving it away with the transmission. What kind of advice are you looking for?
Ya I always follow ur vids. Keep up the good work on the cutty. I need some advice on if I should rebuild my block or buy a new rocket .. where to look for them I don't see nothing on craigslist. And should I get a 72 block I herd there better then the 77 block I have wats the best way on doing it
here is a 71 rocket at the gm sports salavge in my area says to run good... is it a good deal or would be better to put that money to the rebuild of my 77 oldsmobile block? http://gmsportssalvage.com/?q=node/556
$750 seems a bit high for a "pig in a poke" (an engine that you have no way of testing until you install it). I bought one for $50 a few months ago that was a completely unknown quantity, but that, after disassembling it, I could see would have run fine.
I'd say just keep your eyes open and something will come up, but in your area I know that the engines tend to wear out before the cars disintegrate, so you may need to find something from a rustier part of the country and have it shipped.
Get it checked by a local machine shop. If it's got no cracks, go ahead and rebuild. The heads are the only real difference between what you have and an earlier rocket motor. You may want to find a set of 64-72 heads. They will be better than what you currently have.
sounds good a buddy of mine gots a good guy and he going to get me a quote on the rebuild and do a tear down and see if the blocks rebuild-able. ill see if he can find me some 64-72 heads. wheres a good place to look for some heads i like doing research my self too
The best place is right here, post in parts wanted for #5, 6, 7, or 7a 350 heads. Craigslist is also a good place to look. I got lucky. When I posted my head gasket issue (the one that started my foray int 350 cylinder heads) I got several offers from members here. I checked them out, and made a selection that I am very happy with.
So im going to hook up with my friends machinist he has a 350 olds. In stock that he finishing up bit the customer bailed on him. So I might take that one and he is going to quote me on mine so we will see what's going on
cutlassKing
November 29th, 2010 03:05 PM
gscott819
July 28th, 2009 07:02 PM
esisson
May 22nd, 2008 07:47 PM
