Inner Tie Rod grease fittings
Old December 27th, 2014, 04:24 AM
Kenn
kstern58's Avatar
I just got new tie rod ends for my 68 - and noticed that both the inner and outer tie rods have the grease fittings on the bottom of the joint, which is fine for the outer ends, but with the inners there is no way to grease them once installed without removing the pitman arm and dropping the whole assembly because the fitting is too close to the frame. The original inner tie rod ends had the grease fittings on the side. Am I missing something, or has anyone else run into this with replacement tie rod ends?
kstern58 is offline
Old December 27th, 2014, 04:43 AM
??? All the inner tie rod ends I've seen have the fitting on the end. Post a pic. You wouldn't take off the Pitman arm because it's torqued to about 190 ft lbs. who did you buy these tie rods from, because the fitment is pretty much standardized. You have to install the zirc fitting in each end yourself.
EDIT-Are you sure you don't have 2 sets of outers?
Allan R is offline
Old December 27th, 2014, 04:54 AM
Kenn
kstern58's Avatar
Tie Rod Ends
I know I don't have two outers because the threads are correct and the adjusting sleeve goes on just fine. Give me a couple of minutes to get some more coffee and I'll post a pic..
EDIT: All inners have left-hand threads
kstern58 is offline
Old December 27th, 2014, 05:17 AM
Kenn
kstern58's Avatar
Tie Rod Pics
I have not tightened any of this up - they are just placed in position. The gearbox is out for rebuild. I don't want to name the vendor, because I don't feel it's their fault, and I know he'll take the return with no issues. It just strikes me as weird. Obviously, I can't use these - but I'm just looking for a sanity check. Thanks
kstern58 is offline
Old December 27th, 2014, 05:19 AM
Yeah, I did my complete front end 3 years ago, and had no issues with the fitment of the tie rods, pitman connection, idler or drag link. Only part I re used was the pitman arm, and it never came off the steering box.
Allan R is offline
Old December 27th, 2014, 05:46 AM
garys 68&72's Avatar
Any chance you could PM me the vendor or part number on those? I've been looking for a pair of inners with the fitting on the back. Pretty common on A body LS swaps to have the inner tie rod grease fitting to contact the pan. Those fitted with a 90 degree fitting would be perfect for my set up.
garys 68&72 is offline
Old December 27th, 2014, 05:50 AM
I've never seen that either, but can't you just turn the wheels all the way one way and then the other to access the grease fittings? I usually have to do that with the edge-mounted oned anyway.
joe_padavano is offline
Old December 27th, 2014, 06:29 AM
RandyS's Avatar
I encountered the same issue with my 66 project. Swap the straight Zircs for small 90's and you are good to go. You will still have to turn the wheel a bit to get the lube nozzle on them, but it will work.
RandyS is offline
Old December 28th, 2014, 10:57 AM
Ozzie's Avatar
Lightbulb
I've done the same solution that Randy suggested. If that doesn't work for some reason, you could also try a swivel nozzle for your grease gun.
Ozzie is offline
sweet70oldz
July 1st, 2013 03:22 AM
shovel55
March 3rd, 2013 01:04 AM
shovel55
October 1st, 2012 12:24 AM
bigrig12
August 28th, 2012 06:33 AM
Alex72cutty
July 14th, 2012 06:37 AM
Quick Reply: Inner Tie Rod grease fittings
