Grease Fittings
Old June 30th, 2013, 07:05 PM
sweet70oldz's Avatar
Grease Fittings
First of all, Happy 4th of July to week to everyone! Second, I would like to grease up the suspension points on my 1970 Cutlass. What size is the standard factory fitting and what type of grease should be used? I have some new wheel bearing stuff but not sure if this will goof up anything. Thanks and have a safe holiday eveyone. Al
sweet70oldz is offline
Old June 30th, 2013, 07:13 PM
m371961's Avatar
NLGI #2 is the standard chassis grease. There were only 2 different sizes of fittings, and our cars use the smaller one.
m371961 is offline
Old June 30th, 2013, 07:54 PM
Lady72nRob71's Avatar
Wheel bearing grease is usually too thick to push through a grease gun into suspension joints. Use a regular petroleum based chassis grease to ensure some compatibility with what most shops use. Not sure what brands are better than others...
Just get a cartridge size that fits your gun.
Your '70 has 11 places in the front end to grease if i remember right and you are using factory type parts on it...
Lady72nRob71 is offline
Old July 1st, 2013, 03:22 AM
Aron Nance's Avatar
As a quick aside, if your grease fittings won't accept any grease (you'll know right away, believe me) they unscrew and can be replaced; usually found at your local reputable parts house supplier. It' s hard to follow up Rob's response, 'cause he's always so darned thorough!
Aron Nance is offline
kstern58
December 28th, 2014 10:57 AM
bigrig12
August 28th, 2012 06:33 AM
devmar07
May 14th, 2010 09:23 AM
alsmith
March 9th, 2010 09:30 PM
cornwallis
September 21st, 2009 08:44 AM
Quick Reply: Grease Fittings
