Identifying 1970 Radiator Supports
Old June 22nd, 2021, 07:11 PM
Okie Rocket's Avatar
Does anyone know how many different Radiator Supports there were in 1970?....... i.e., Is a 442 Radiator Support a different Part #, or is it different in some way from a Cutlass S or Supreme, etc.?....and are 1970 - 1971 - 1972 Radiator Supports different in some way by year, or Do they have different Part #'s stamped into them?
Harold
Okie Rocket is offline
Old June 22nd, 2021, 07:22 PM
same but different
don71's Avatar
Core supports are different for all three years and have different part numbers. 1970 is unique for at least the hood latch and grill mounting and will not work for 1971 or 72.
1971 and 72 are quite similar but have important difference considering the grills.
It's best seen in photos that point out the difference.
don71 is offline
Old June 22nd, 2021, 07:49 PM
same but different
don71's Avatar
https://classicoldsmobile.com/forums...pports-142911/
https://classicoldsmobile.com/forums...stions-128729/
don71 is offline
Old June 23rd, 2021, 05:14 AM
There was only one P/N core support for the Olds A-body cars in each year. They are different every year, but the same within a model year.
joe_padavano is offline
Old June 23rd, 2021, 07:22 AM
Joe, I had noticed in the 1970 Assembly Manual that there were a couple of different numbers showing for the Radiator Support "Assembly." (i.e., 405125 for C60, Y72 and V01 + 405119 for Std.). Now, with your information, I'm thinking that the only difference between the two numbers is a different size pair of Radiator Saddle Brackets to hold the Radiator to the Support + maybe? some other small changes (misc. drilled holes, etc.??.............i.e., with the actual Radiator Support itself being the same Part between the 2 different "Assembly" Numbers? Is this correct?
Old June 23rd, 2021, 09:09 AM
Good point, thanks for catching that. The differences are the brackets welded on for the radiator. Four row radiators have wider brackets, so yeah that assembly has a different part number. The brackets are spot welded to the core support. Sorry I should have clarified that.
Old June 23rd, 2021, 12:08 PM
No problem at all Joe. Thanks for all of your great information!
Harold
THANKS to everyone for all of your help!!!
Old June 23rd, 2021, 02:15 PM
Stefano's Avatar
Also, some have 2 tabs welded to the bottom of the core support for a fan shroud provision while the ones built without a fan shroud do not. I believe this is consistent with 3 core vs 4 core radiators.
Stefano is offline
Old June 23rd, 2021, 02:39 PM
Thanks for the info!
Zr1bandit
August 9th, 2017 04:45 PM
Zr1bandit
June 25th, 2017 03:43 PM
cdoering
March 23rd, 2015 06:48 PM
Last98
December 26th, 2013 06:21 PM
my442conv
January 31st, 2012 08:28 AM
Quick Reply: Identifying 1970 Radiator Supports
