Door Hinge Pin with detent roller
Old July 21st, 2011, 09:13 PM
atkinsom's Avatar
Need to replace the hinge pin on the drivers side door with the roller that the little arm glides across when you open and close the door. The roller is almost coming completely off. I'm buying a door hinge repair kit that include the pin with the roller.
How do I remove the spring on the hinge so that we can get the pin with the roller out?
Does the whole pin come out with the roller included from the hinge and then you slide the new pin with roller back through the empty slots?
Thanx everyone
atkinsom is offline
Old July 22nd, 2011, 08:37 AM
With a door hinge spring compressor, available at any auto parts store:
joe_padavano is offline
Old July 22nd, 2011, 09:59 AM
atkinsom's Avatar
Thank You Joe.
atkinsom is offline
Old November 7th, 2012, 11:02 AM
jamac's Avatar
And old thread but---how did you remove the old hinge?
I have a '67 with the same problem but I am struggling with how to remove the hinge, etc.
Tight spot and some kind of strange wrench needed?
From there I guess you drill out the old pin. OPGI has a replacement pin (stub) with roller.
Part #CHV0469
jamac is offline
Old November 7th, 2012, 11:05 AM
jamac's Avatar
Here is the OPGI repair kit URL:
http://www.opgi.com/p/body-moldings-...5/CHV0469.html
jamac is offline
Old November 7th, 2012, 11:27 AM
NOVICE car nut
oldsguybry's Avatar
Good to know ... I have the same problem with the drivers door on my car .
oldsguybry is offline
Old November 7th, 2012, 12:38 PM
jfb
jfb's Avatar
check into a oem hinge the aftermarkets have there problems. once they are bad most usually need replacement.
jfb is offline
Old November 8th, 2012, 10:02 AM
Lance
ROCKET VAPOR's Avatar
Willie will restore your originals or sale you the replacement parts.
http://www.hoodhingerepair.com/
ROCKET VAPOR is offline
Old November 8th, 2012, 12:21 PM
Lady72nRob71's Avatar
You can also repair your own hinges at home to be as good as new.
Here's my tale...
https://classicoldsmobile.com/forums...storation.html
Lady72nRob71 is offline
Old November 9th, 2012, 08:45 AM
jamac's Avatar
All good info.
The question I have is how do I remove that lower hinge?
Is there a special wrench?
Special mehodology?
Once I get it off, looks like repair is not so difficult.
jamac is offline
Old November 9th, 2012, 09:53 AM
There is a special wrench for removing the hinges, but I was able to get mine on an off with standard wrenches, a ratcheting box wrench, and an offset box wrench.
Earlier and later in my interior makeover thread, I described how I did it.
1970-W30
Body work
December 11th, 2012 03:49 PM
69postman
Body work
January 29th, 2012 05:07 PM
arodenhiser
May 19th, 2010 01:03 PM
Redog
August 14th, 2008 06:56 PM
69 Cutty
August 24th, 2006 08:16 PM
Quick Reply: Door Hinge Pin with detent roller
