71 Cutlass Frame Diagram
Hey guys, I dont know if there is such thing... but I need a diagram with all the dimensions of my frame... While inspecting the underside of my car, I noticed that the frame had some major cracks, and a pathetic attempt at a weld job, right infront of the crossmember. It looks as if someone tried a 'Dukes of Hazzard' jump with my girl
Ive got a mechanic that can help me out with the job, he just requested that I find the diagram with proper dimensions for it. If anyone knows where I can get one it would be greatly appreciated
What a bummer, dang Hollywood rednecks.
Didn't the red color, stars and bars on the roof, the big 01 painted on the welded shut doors and the rollbar tip you off when you bought it?
It could be a lot worse, at least it ain't a Dogdge.
The chassis service manual has this if it helps.
It also says that after the frame menbers are riveted or bolted securely all welded joints or any cuts that were made should be welded.
It's sort of obvious but they have to say it or you know what would happen.
Its weldable, so were going that route. Ive seen this guys welds on frames and it looks like a robot did it so im not too worried... Thanks for that diagram Bluevista, but im looking for something much more detailed. I dont even know if it exists, but I need dimensions for pretty well everything haha :P
I would get another frame too, just R & R if you can turn a wrench and have tools, jacking devices, sawhorses, lumber, a cherry picker and lots of friends.
Body/ frame shops had detailed frame dimension charts with the numbers for any car so they had them.
This evilbay dude has them for 5 bucks.
Smart move to use a Cadillac one in his listing pic, I would have ripped it off if it was the Cultass diagram.
http://cgi.ebay.com/ebaymotors/1971-...sQ5fLiterature
Well I went to the two body shops we have in town, neither of them have the diagram I need. One of the guys actually started to give me crap for having a friend weld it without having a frame machine to check everything. Little does he know that the frame is straight, because I did the cross-measurements, they are fine. I put it on a flat floor, jacked the front up to be even with the back, and measured both sides from the floor to the frame. Thats also straight lol. so the only issue is those two cracks before the crossmember. So I let him ramble and grumble about me not doing it right, thinking maybe he would say something I dont know yet. The only thing he did say that I liked was about a guy just outside of town that used worked at the GM dealer in town for like 40 years, that has a massive warehouse dedicated to GM behind his house. Im going to go visit that guy to determine if hes a hoarder and wont part with anything, or maybe he will cut me some sweet deals
Just a little update in case anyone is following lol.
I have a very detailed frame diagram with all possible measurements for a '70 Buick GS from a frame shop.
If anyone can confirm that the Cutlass frame is the same, I'll post it when I get home from work.
Rodney, thx. I got that one somewhere up here on CO and roughly caculated it was like 14 ft or so. Just needed to know what vehicle needed to haul it from a POS powder coater who held it for 10.5 months and did nothing with it.
