Frame Rust
Frame Rust
So i banged all around my frame with hammer pretty hard since thats the only test i really can think of and this is the only bad part i really found and it looks pretty bad. Im not looking for show quality or even a daily driver and really dont want to do a frame off but i realy want do something to this section. What can I do for this part of the frame and where should i go?
Oh no!
That's not good at all. Where on the frame is that? If it's just under the trunk floor, it's not so bad. If it's up front somewhere that sees turning and motor flex, I'd tear the car down and get it some help, or get another Cutlass.
Remember, the entire body of your car is only held onto the frame, by 10 bolts. Rotten frames are no joke if in a bad spot. Check all of your body mounts and make sure that they haven't pushed through into the top of the frame anywhere.
Hmm...
I guess now it depends on what kind of time, budget, and plans you have for the car.
For a cheap-o fix, you could take a die grinder with a cutoff wheel and cut out the rot. Sand blast the crap out of it, and weld a big piece of steel in there.
If this car isn't going to see much weather, horsepower, or hard riding time, you'll get away with that repair for years to come.
If you're going to soup this thing up and beat on it, I'd start over with something else, or get that frame of yours out from under the body and do it up proper.
Frankenpez
February 2nd, 2009 07:03 PM
