70 delta ragtop body mounts...
Old January 30th, 2015, 04:34 PM
ragtopolds6@zoominternet.'s Avatar
hi guys ..new member here...looking for body mounts for 70 delta 88 vertible...was wondering if vista cruiser would fit....thanks all
ragtopolds6@zoominternet. is offline
Old January 30th, 2015, 05:48 PM
Welcome to the site, I moved your thread here to get you an answer to your question. Post a proper intro in the newbie section when you get a chance.
oldcutlass is online now
Old January 31st, 2015, 06:35 AM
Tiger69
Tiger69's Avatar
The are both C Bodies so I would think that is good. I just went through a month of searching and researching for body mount bushings on my 1965 C Body (4 door 98), and when I had the frame off I saw where the convertible has two extra bushing mounts which I would not think the Vista has. I had to measure the frame holes and bought a combination of generics from Steele Rubber, Metro, and ended up buying the main bushings from a 68 Buick electra (10 of them), and put them on a lathe, and cut down the centering rubber bushing from 1.5" to 1 1/8th. They worked perfectly. Not saying I did the right thing, but it worked on a '65 C-body.
Tiger69 is offline
Old March 9th, 2020, 02:14 AM
Love1955oldsmobile's Avatar
Do it yourself body mounts
Here is what i did for my 1955 98. I went to a wholesale / commercial rubber dealer that sells sheets of rubber in various thicknesses. I wanted my mounts to be slightly thicker by 1/8 inch as i thought the original mounts had compressed by that amount over the many decades. Mine are square where as the newer mounts are round. I also made my mounts slightly larger by 1/8 inch to overhang the steel frame support arms to provide a little more give. Cuts easily with a hacksaw and easy to polish the raw cut edges. Way cheaper than some mount kits i researched.
Love1955oldsmobile is offline
Old March 9th, 2020, 04:59 AM
Here's another good thread on body mounts (for those doing a search):
https://classicoldsmobile.com/forums...a-88-a-139664/
Olds64 is offline
mbrule
August 29th, 2017 07:40 AM
a70oldscutlass
June 3rd, 2016 07:31 PM
oldschmo
June 23rd, 2012 10:20 AM
Shradezz70S
February 19th, 2012 08:11 AM
kevdog442
July 22nd, 2008 02:31 PM
Quick Reply: 70 delta ragtop body mounts...
