Care and Appearance Washing, waxing, paint care products, etc.
Power Polisher
Old June 13th, 2015, 09:27 PM
Dr.Olds Illegitimate Son
Maverick's Avatar
Power Polisher
Hi guys,
I purchased a 7" power polisher/variable speed . Should I be able to stall it out ?
Maverick is offline
Old June 14th, 2015, 05:44 AM
Rocketowner's Avatar
No, but you need a rotary polisher that will produce about 3500 RPM. If you are not experianced using this type buffers,start out with something like Mc Guires Ultimate Polish. Dab on a small amount of polish on half of a panel, tilt the buffer at about 20 degree angle and let the polishing be done with the edges on the lower edges of the tilt(don't hold flat and do not push your weight onto the buffer) .Let the buffer do the work! When buffing side surfaces,make sure the cord is lower than the buffer pad,otherwise the cord will tangle around the buffer head doing 3500 RPM's (and result in breaking a bone or throwing you to the floor ) unless you can manage to turn it loose.Never let the buffer pad directly touch sharp edges.Go carefully and it should do fine.when you achieve the look you want, then hand wax with any 100% Carnuba wax(such as McGuires Ultimate or Mothers Gold. I Would also recommend a wool Pad. Good luck, Larry
Rocketowner is offline
Old June 30th, 2015, 07:03 PM
Ryan McManus's Avatar
Adams Polishes is a great product with 110% guarantee and the forum has plenty of knowledge
Ryan McManus is offline
squirell
April 13th, 2011 05:22 PM
Uly49
October 20th, 2009 07:11 PM
my69olz
Care and Appearance
July 8th, 2009 10:31 AM
KZ442
April 10th, 2009 03:16 AM
1FSTLS1
May 30th, 2008 07:42 AM
Quick Reply: Power Polisher
