Care and Appearance Washing, waxing, paint care products, etc.
painting plastic fender wheels
Old June 25th, 2010, 05:30 PM
1973olds98's Avatar
I am preparing my engine bay for my newly rebuilt 455,,,I want it to look just as good as the engine,,My main concern is the plastic wheel well liners,,,I have prepped them and painted them but they just dont look good..They have to many imperfections that show through the spray paint...I used truck bed coating to cover the cross member and firewall,,,That stuff goes on thick and covers any imperfections,,Can this stuff be appied to plastic? It would work perfect on the plastic wheel well if it will work,,,Anyone use this stuff on plastic?
1973olds98 is offline
Old June 25th, 2010, 07:48 PM
What did you paint them with? Most paints don't adhere well to plastic. Can you post pics of what they look like?
You might want to check with a local body supply/paint in your area. They might be able to give you a good lead on the type of bonding agent and paint you need to use.
Allan R is offline
Old June 25th, 2010, 11:13 PM
1973olds98's Avatar
i painted them with bumper paint i bought from autozone that is meant for plastics,,,
Old June 26th, 2010, 06:26 AM
Nilsson's Avatar
Use SEM satin black, it is durable and it coats excellent. Not a cheap process because of the prep and the prep materials required.
But you get what you pay for.
Nilsson is offline
Old June 26th, 2010, 07:12 AM
Lady72nRob71's Avatar
The SEM 'surecoat' will require their 'adhesion promoter', even if the datasheet may not say to use it. I learned the hard way...
My inner fender plastic looked a bit ragged but I used fine-medium scotchbrite on them and used medium-light pressure. They looked almost new afterwards.
Of course this will be too difficult if they were painted already.
Lady72nRob71 is offline
Old June 26th, 2010, 07:10 PM
tim72's Avatar
I hand buffed the inner fender wells with 3m plastic polish. It took a long time and it was a pain but hey came out nice taking a lot of the fine scratch's out. You may be too far to try this approach.
tim72 is offline
Old June 28th, 2010, 06:15 AM
Did you remove the inner fender wells when you painted them? If not then you might consider removing them and cleaning them thoroughly before painting them. I would think the Krylon Fusion paint that you can get in the hardware store would work well. I used it on some interior pieces in the past with great results.
Olds64 is online now
442dreamer
Wheels and Tires
June 11th, 2011 09:04 AM
Gary's 2 442-S
December 28th, 2010 01:57 PM
cutlass47
Paint
22
September 6th, 2009 07:23 PM
Lady72nRob71
September 25th, 2008 05:31 AM
72rocket
January 13th, 2008 02:39 PM
Quick Reply: painting plastic fender wheels
