1997 Bravada window problem
Old July 16th, 2023, 10:37 AM
deaddds's Avatar
Just got a 97 Bravada. All the windows work from the master control but none work from the individual doors. Power mirrors work as well as locks. Not sure if this means the lock out on the driver door panel is jacked keeping the others from getting power. Any body else had this issue? Thanks Pat
deaddds is offline
Old July 16th, 2023, 12:19 PM
Could be the safety switch on the driver's door as you suspect. It's probably worthwhile to disassemble the door panels and test with a multimeter. Do you have an Oldsmobile manual for your Bravada?
Olds64 is online now
Old July 16th, 2023, 04:59 PM
deaddds's Avatar
I’m not sure. I’ll go thru my books to see if I have one.
deaddds is offline
Old July 24th, 2023, 07:49 PM
jcdynamic88's Avatar
you don't have to disassemble the door panel to access the switch assembly,it lifts out of the door panel from the front,the rear of the switch panel hooks under the door panel
jcdynamic88 is offline
Old October 14th, 2023, 06:33 PM
deaddds's Avatar
It was the lock out switch.
deaddds is offline
yellowone
September 23rd, 2019 09:01 AM
TCNakaya
January 21st, 2013 07:52 AM
Rdrokit
May 28th, 2009 08:12 AM
real442
March 8th, 2008 07:03 PM
jrbarrie83
July 4th, 2006 09:16 AM
Quick Reply: 1997 Bravada window problem
