Disc spindles interchangable with drum spindles?
Old March 7th, 2013, 10:56 AM
Murco's Avatar
Hi folks!
Well, it's time to get the Cutlass ready for cruising season and we've wanted to do a disc-swap for some time. I've had other projects keeping me busy and one of them is a "new to me" 1970 Firebird that we are going to go hog-wild on!
Here is the question... The firebird has all new brake components on it - rotors, seals, bearings, calipers, pads, hoses, master cylinder/booster and refurbished spindles. The 1972 Cutlass has power brakes, uses drums all around and is all original. I know later Cutlass and Firebirds used the same spindle, could the spindle assemblies from the Firebird be swapped over to the Cutlass? Are the a-arms and ball joints different on OEM disc cars?
This would be a pretty convenient way to swap them on the Cutlass since the Firebird is getting the whole C6 conversion!
Thanks!
Murco is offline
Old March 7th, 2013, 11:28 AM
boese1978's Avatar
You can use your Cutlass drum spindles with the kit from www.scarebird.com to convert to front disc.
boese1978 is offline
Old March 7th, 2013, 11:50 AM
Originally Posted by Murco
Hi folks!
Thanks!
Sorry, but you've got your model years confused. Spindles from the 64-72 A-body cars interchange with FIRST GEN (1967-69) F-body spindles (and 1968-74 X-body spindles). The second gen F-body (1970-1981) uses completely different spindles with different ball joint tapers and integral steering arms that are not in the correct place to give proper steering geometry on an A-body. Once again, if this swap were that easy, the cost of repro A-body disc brake spindles would be a lot lower.
joe_padavano is offline
cdrod
Brakes/Hydraulic Systems
September 11th, 2014 05:54 AM
cheven
February 16th, 2012 08:44 AM
rogiestone
October 18th, 2011 06:11 PM
The_Jeremiah
October 3rd, 2007 06:38 AM
Jhain85
July 10th, 2007 09:16 AM
Quick Reply: Disc spindles interchangable with drum spindles?
