brake line replacement question
Old January 1st, 2012, 11:57 AM
denf221's Avatar
I have a 64 lemans I am working on. I just took off the brake line that runs from front to back. I am having alot of difficulty with bolt that is on the back end of the line where it mounts to the rear crossmember. The bolt if rusted and pretty rounded off, I just tried using a closed end wrench but even that pretty much travels around the bolt, any tips for getting this thing off.
denf221 is offline
Old January 14th, 2012, 08:42 PM
buzz lightyear's Avatar
Is it a bolt or the thread nut on the brake line. If its a bolt, they sell sockets that get stripped bolts off. Used them my self on rounded bolts. Got one that was very tight on it and hammered it on, to get a tight fit. Worked good for me. If it is the nut , I would squirt WD-40 on it , couple times a day, for a couple days, and the put some vice-grip pliers on it, and see if that takes it off.
buzz lightyear is offline
Del70
November 15th, 2013 02:24 PM
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
bpnoel
September 27th, 2010 07:58 AM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: brake line replacement question
