Fixing a disc brake spindle
Old October 28th, 2010, 10:03 PM
oldzy's Avatar
Anyone ever done this? The garage I go to mentioned having a machine shop build up the metal that is chewed up. I do not want a repro spindle.
oldzy is offline
Old October 29th, 2010, 08:44 AM
The welding and remachine option works fine if done properly. The bearing surfaces don't see any relative motion with the bearing inner race under normal use anyway, so you should be fine.
joe_padavano is offline
Old October 29th, 2010, 09:44 AM
Oldsdruid
rocketraider's Avatar
I've seen it done on electric motor and pump shafts to salvage them. Think the technique is called "spray welding". Get it built up enough to work, then machine it down to specs.
My tightwad dad had that done on a jet well pump when I was in grade school. It would have been simpler and about as cheap to have replaced the pump.
However I can understand wanting to save your original spindle. A refurbished GM forged part is still better than a new Chinesium cast part.
rocketraider is offline
Old October 29th, 2010, 09:51 AM
car guy
gearheads78's Avatar
I think as common as the part is just find another. The machine shop bill will be more than a replacement core.
gearheads78 is offline
Old October 29th, 2010, 10:25 AM
Find another? To quote Woody Allen, they usually travel in pairs...
Also, they usually travel as part of a complete disk brake conversion setup.
Mocephus
October 1st, 2021 09:45 AM
olds70supreme
May 16th, 2018 05:48 PM
oldzy
December 17th, 2010 04:37 PM
1001coins
February 26th, 2010 09:29 AM
perro
Brakes/Hydraulic Systems
September 3rd, 2007 01:30 PM
Quick Reply: Fixing a disc brake spindle
