Rear brake noise
Old October 24th, 2017 | 02:06 AM
cus's Avatar
cus
Rear brake noise
Have a bit of an issue with the rear drums on a 73 delta. Have replaced shoes & wheel cylinders, brakes are working well but I'm getting a clacking noise every now & again. Thought it was the backing plate having grooves on the contact points, so filed them flat & put some grease on them, noise went away for a while but came back again recently. Noise comes on when coasting down the road at about 50-60 , I've pulled up, given the brakes a few stabs, put in reverse etc., take off & it comes back again, can go away for quite some time, but seems to not be cured. It's almost like the brakes over adjust a bit & the shoes are pulling on the springs, back & forth, clack, clack, clack, can get pretty loud.
Old October 24th, 2017 | 04:56 AM
wifespain's Avatar
sounds like your return springs are weak, not allowing the shoes to return once you release the pedal. I would install all new brake hardware, and while you're at it, new shoes, both relatively cheap.
Old October 24th, 2017 | 06:55 AM
Check the drums for concentriciy of the friction surfaces to the locating pilot. If they are out of round, the shoes will be moved back and forth. This can cause your noise and can also eventually lead to overadjustment of the shoes by actuating the self adjusting linkage prematurely. I've had exactly this problem with two different sets of brand new (Chinesium) brake drums on two different vehicles.
dewcrazzy
June 24th, 2013 05:02 PM
brown7373
April 30th, 2012 06:41 AM
hurstolds-101
Hurst/Olds
April 20th, 2010 02:59 PM
hurstolds-101
Drivetrain/Differentials
April 20th, 2010 08:25 AM
sully
Brakes/Hydraulic Systems
March 30th, 2007 11:26 AM
Quick Reply: Rear brake noise
