Suggestions for 1995 88 brake lines?
Just starting to put this car back on the road and noticed brake fluid leaking under the ABS pump. The lines around there are pretty rusted. Should I bend some new lines from a bulk roll and use the existing fittings? Buy a whole set of pre-bent lines?
