1972 Cutlass can't get brake fluid to wheel cylinders
Hey all, Old car here, not run in a decade, But 350 started right up after I did the normal things. So brakes are next so I can test Tranny.
I got a new master cylinder and bled it. So far I can get fluid to come out of only one brake line (front driver side - closest to MC. I tried using the brake suction hand Vac to get fluid to passenger front and rear. No dice, dry as a bone. Would it be correct to think that somehow the distribution block about two feet underneath the master cylinder is blocked and corroded enough to stop the flow brake fluid. I don't have any leaks under the car and under the drums actually look fairly good. Suggestion on the next step. I am thinking I should take the lines off the distribution block and replace it. Thanks for quick reply.
If it were me, I'd first make sure the bleeder fittings are clean of rust, debris. Remove and run a small wire through them. If that fails to move fluid, see if you can crack the brake line at each side of the rear cylinders and get fluid to move there. Then move on to another plan.
Take the left steel line loose from the rubber line and see if you get fluid there. The old rubber lines are known to collapse internally and block flow. If you get flow there move on to the rear line. However if there was a loss of pressure to the rear brakes the valve in the distribution block will close and block flow to the rears. There is info on the net on how to center the valve and bleed the brakes without it closing again.
jpatfarrell
Brakes/Hydraulic Systems
17
January 26th, 2019 09:51 PM
