New brake bleeding tool
Old June 6th, 2015, 09:12 AM
This is one of those "why didn't I think of that" tools.
One frequent problem when bleeding brakes on dual circuit systems is that the piston in the differential pressure switch can get forced all the way to one side or the other and block that brake circuit from flowing. This problem is compounded if you have an original cast iron combo valve that might have rust in it, as the piston gets stuck.
PerformanceOnline.com has just come out with a clever tool that simply screws into the distribution block or combo valve and locks the differential pressure switch piston in the center position while bleeding the brakes. You simply unscrew the plastic switch body, temporarily replace it with the tool, and bleed the brakes. No, brake fluid will not leak out, as the space around the piston is dry and sealed by o-rings. If you do get fluid, the valve is bad anyway.
Just remember to put the switch back in when you're done. $8 online.
https://www.performanceonline.com/Co...ve-Bleed-Tool/
joe_padavano is online now
Old June 6th, 2015, 09:27 AM
Whoa. Dude. That's a smart little tool.
MDchanic is offline
Old June 6th, 2015, 06:38 PM
Yellowstatue's Avatar
I like it! I like it!
Yellowstatue is offline
Old June 6th, 2015, 06:53 PM
Octania's Avatar
Evidently they never learned that "cutaway" is one word.
Definition #3
http://dictionary.reference.com/browse/cutaway?s=t
great idea for a tool, and modestly priced
Octania is offline
Old August 19th, 2015, 07:46 PM
crimsoncolby's Avatar
I used this tool a couple summers ago and it worked like a charm. Love it when something this inexpensive can save so much time and frustration.
crimsoncolby is offline
Old June 27th, 2020, 11:46 AM
Originally Posted by Orlando 1
When removing make sure the pedal is 1/2 depressed so the master valves close and you don't reintroduce air into the line.
There is no brake fluid behind the differential pressure switch. If there IS any fluid, the seals in the distribution block are bad.
Old June 27th, 2020, 03:48 PM
While I thought the tool is cool when you first posted this and have recommended it or similar since for the newbies. I still in all my 40+ years of doing brakes have never needed it to bleed brakes and I still do it the old fashioned way with a my pretty helper to pump the pedal.
oldcutlass is online now
Old June 27th, 2020, 05:11 PM
I'm trying to determine how a five year old post is resurrected with a quote by someone (Orlando 1) who doesn't even have a post w/in the thread. I think I got too much sun today.
Vintage Chief is online now
Old June 27th, 2020, 07:33 PM
O'smobile
Orlando 1's Avatar
I was stupid and removed the stupidity.
Orlando 1 is offline
Old June 28th, 2020, 05:39 AM
I...removed...
Pewter442
Brakes/Hydraulic Systems
41
March 14th, 2015 07:02 PM
PhilGGG
December 18th, 2013 07:06 PM
Deputy442
September 5th, 2008 05:15 PM
Bluevista
May 21st, 2008 10:20 AM
projectheaven
May 15th, 2008 01:11 PM
Quick Reply: New brake bleeding tool
