Brake bleeding
Opening the bleed nuts, taking the lid off the master cylinder, and letting gravity to it's thing. I have never done it that way but many people here have and like to do it that way. I used to have my wife do the foot pumping for me but she isn't strong enough now to hold it down (can't drive any longer either do to weakness in her legs) so I have to enlist the help of someone else or do the gravity thing or get one of those one-man brake bleed kits.
I have used the poor mans brake bleeder.. a BROOM STICK ! pump up three times, wedge the broom stick between the pedal and the seat, go and open up the bleeder valve. It's a lot of work but when you don't have someone around to help and you can't find your one man bleeder tool, it works !
I tried the broomstick once but it dropped loose the first time, there was lots of air in the system. Instead, a short chunk of 1x12 long enough to leverage the pedal weighted by a cinder block; or just a cinder block depending on the car.
PhilGGG
December 18th, 2013 07:06 PM
