Convertible Top Hydraulics: Brake Fluid, PS Fluid or Transmission Fluid?
Old June 7th, 2009, 08:45 AM
cfair's Avatar
What's your vote? I've used both along the way. I can't remember what's factory, but I know both work.
The key difference seems to be what smell develops and how much paint is left under the back seat when you blow a seal or hose...
Thanks in advance.
cf
cfair is offline
Old June 8th, 2009, 12:37 AM
Yellowstatue's Avatar
Exclamation Slick
Do not use brake fluid because it does remove paint! The book reads-use hydralic oil- I would read that as meaning trans fluid, but PS fluid would also work as would other hydralic oils such as #32 or #68 or whatever you have as long as it is not too thick...
Yellowstatue is offline
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
1976Oldswagon
January 3rd, 2014 09:18 AM
henryk8398
March 15th, 2010 04:04 PM
mahoneybags21
March 11th, 2009 10:16 PM
70redvert
December 22nd, 2007 04:53 PM
Quick Reply: Convertible Top Hydraulics: Brake Fluid, PS Fluid or Transmission Fluid?
