Brake Fluid Amount ?
Dr.Olds Illegitimate Son
Hey guys,
I'm doing a power front drum to power front disk brake swap on my 1971 Olds Cutlass Supreme convertible.
My question is how much NEW brake fluid will I require ?
Brent
Brent
If you're doing a front brake conversion, you may as well also flush the entire brake system while you're at it. No point in leaving old brake fluid in the lines from the prop valve back. Who did you get your conversion kit from?
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
