Am I running low on brake fluid?
#41
Ok a bit of hope!!! I think we all no someone who can do brakes. Yes parts may cost a few bucks, but you can find parts stores, or parts supply companies such as USA Parts Supply.com for specialized hard to find parts for your brakes. Talk to your mechanic or his employees and see if one of them wants to do the brake job "on the side". First take it to a mechanic you have confidence and trust...NOT A TIRE AND BRAKE NATIONAL STORE!!!.
No what your complete brake problem is...its important to know the whole problem and then make a plan of attack. I had a handi-man (construction type) help me with my brakes....it cost 50.00 and a six pack an a burger on the grille for his help and a hell of alot more fun then the "wife" being my aid. Nothing against the wives but lets be honest, when that wrench slams into your bare knuckles and all you want to say is @#%&*@#!! the wife just should not be around.
#42
Keep shopping for a better qoute now that you know whats wrong($500 are you kidding me!)........A CL add for a muscle car guy to swap out the problem might net some surprising results.......Jerr
#43
Fair enough, Rickman, but I'd say your story is an argument for doing it yourself and not letting some stoned kid with a surgically attached iPod do it.
I know this guy isn't an expert, and I would never recommend that he or anyone else attempt any work they weren't sure they could do (or maybe I should use the confidence : competence ratio, which should always, no matter what, represent a value < 1, and say that if he's completely certain he can do it, then maybe he doesn't know what the job entails), but I would classify changing a master as a beginner-level job, the kind of thing I remember doing in a parking lot when I was 18 without a second thought.
I would never try to talk him into doing the job if he felt reticent, but I believe that considering the cost differential of $500 to $20 (that's 25:1), it's only fair to provide him with a description of what's actually entailed in doing the job so that he can weigh his options and make the decision that's right for him. If he puts in a new master and has no brakes, or has a leak he can't stop, he can stay in the driveway and get a tow to the shop of his choice. Perhaps I lack imagination, but I can't see a master cylinder installation scenario that creates a danger of sudden failure on the road if, when the job was done, all fasteners were tight, the brakes worked properly, and there were no leaks.
ps: besides, you and I both know that he's going to take it to a shop anyway, right?
#44
Eric - I think we're on the same page - I was only trying to influence a correct job.
Having had a brake line break, in rush hour traffic, approaching 6 cars stopped at the redight in front of me at 45 mph, makes me a little outspoken about brakes!
'65 Jetstar I with the 4:33 gear, [towing package] a working E-brake and downshifting got me stopped, thankfully! Could've been real bad - line broke with the frame, and a single master cylinder!! Welded at a frame shop and line spliced for about $100 - 30 yrs. ago!!
Better to be verbally 'carried away' about brakes, than physically, IMO!
And people who don't know a screwdriver from pliers shoudn't be learning on brakes!
Rick
Rick
#45
Single circuit masters scare the crap out of me.
#46
Thanks for all the help and concern with this issue. I'll be the first to admit that I'm no mechanic (compared to everyone else here), but I am great at following instructions. I'm not saying this compares, but I had to change the water pump on my car. Had no idea what anything was, but was able to read / ask / research enough to do it. Even typed up a tutorial for the next guy like me get some help:
http://www.oldsmobilecentral.com/201...70-cutlass.php
Now, I do understand the concern here since this involves brakes. If I could, I would like to learn how to do these things on my own. I'm a computer engineer, not a mechanic, but I would like to learn. One of the reasons I got the car.
Changing the master cylinder doesn't seem that complicated. I have a friend and a friends dad who know way more about cars then I do that can help. I probably going to follow @MDchanic advice.
Worst case here, I loose about $30 bucks and a couple hours. Dont think when I drive this car I'm cruising down the interstate now. I test it on a straight, no traffic road right outside my house.
Again, thanks for the help and concern, I hope it is something just dealing with the cylinder and booster (but hopefully just the cylinder).
I'm not going to bight off more then I can chew.
A bad master would very likely do just what you've seen, and, with no obvious leaks, is the most likely problem. Removing the mounting bolts and pulling it away from the booster would reveal brake fluid on the booster side, where it shouldn't be, making an easy diagnosis.
As for $120 in parts, I show a rebuilt master from Advance for $17.09.
If it were me, I'd drop twenty bucks on a master, remove the two lines
then remove the master,
then bench bleed the new master as described in the instructions that come with it, reattach, tighten fittings almost all the way, bleed it from the fittings once or twice, then just drive it if you've got a good pedal, and bleed the whole system when you've got the chance (but hopefully within a day or two, because that fluid looked like $hit).
(careful if the fittings are rusted to the lines - you don't want to twist the lines, only to turn the fittings. Apply a good penetrating oil (like KROIL). Use a 5-sided flare nut wrench on the fittings and tap it smartly with a heavy hammer to break them free. If the lines want to turn with the fittings, then gently work the fittings back and forth on the lines, without twisting the lines, using plenty of penetrating oil, and you will free them so that they can spin, THEN unscrew the fittings from the master, making sure to place plenty of paper towels beneath them to soak up the brake fluid),
then remove the two nuts holding the master to the booster, then remove the master,
#47
Speaking of single master cylinders. My 1963 Starfire is a single and I think about that every time I take it out as I have had ruptured lines happen on dual masters and that's scary enough. My GMC blew a line while hauling a trailer and I was stopping for a school bus. That was exciting. Has anyone changed their single to a dual? Just thinking about it I assume I would need 1. dual master 2. proportion valve 3. re-route some brake lines to fit the valve & master. Do 1964 88's have duals? Maybe I could use the parts from that system if they do. Thanks guys for any info.
#48
With rare exceptions, dual masters began when they were first required, with the 1967 model year.
I'm sure you can look up your wheel cylinder numbers, check which '67 and later cars used the same cylinders, and then do the plumbing for a master from one of those cars (you could also go for a slightly larger or smaller master cylinder bore to make your brakes harder or softer, as you prefer).
Others here could probably just tell you which units to use off the tops of their heads.
#49
I'm a little surprised at the overly cautious "get a pro" advice offered here. Sure, you need to ensure that the brake system is fully functional, but it's really not that complex. We all had to learn to tell a bleeder from an banjo bolt at one time or another. If you never attempt to do it yourself, you'll never learn. More importantly, there's no guarantee that a shop, especially a discount chain, will do a better job than you would. One thing is for certain, however. Any shop you go to will almost certainly upsell you on repairs.
Get a Chassis Service Manual, take your time, and use common sense. Don't go out on the street until you are sure that the brakes work properly in your driveway. If necessary, find a friend with experience to double check your work. This ISN'T rocket science.
#51
Maybe some reading on how a brake system (hydraulic) operates will help you.
Once you start pulling things apart you're going to go ....."Wow...that was simple".
http://www.youtube.com/watch?v=rgbDyJhBb4c
http://auto.howstuffworks.com/auto-p...disc-brake.htm
Well, I did just drop it off to NTB since they have free brake inspecton. They just called and said fluid was leaking in my booster and that and the master cylinder needs to be replaced. That with a flush would be $500. I'm not sure how they could actually tell it was leaking in the booster. That's a lot of free labor for free. Do you agree with this. Should I just get flush and see what that does? I can get the new parts from advance autoparts for $120. Is it tough to replace?
I just learned how to flush and fill my brake system and change components.
My only advise is don't buy a repop master cylinder replacement. Get a new one from Rock Auto
Properly bench bleeding a new master is key to saving yourself headaches too.
IF you have a compressor in your garage, or can borrow one it makes life 100x easier to bleed your system faster. Harbor Freight has a cheap version of the Vacula system ($200) for only $30. Save the $500 and learn how to do it yourself and spend that money on UPGRADES to your system.
Here's the brake bleeder @ Harbor Freight.
http://www.harborfreight.com/brake-f...der-92924.html
#52
#53
I'd still bench bleed the master. Getting a seal on the bleeder screws isn't something I've
mastered perfectly yet. I was told to crack the bleeder and put grease around it's base
to somewhat seal it. Other people said not to do that because you'll contaminate the fluid.
The Vacula siphons air from around the bleeder threads if you don't. At least that's been my experience so far.
It's not a perfect science.....lets put it that way. LOL
They sell those $10 bleeder screws with that tough thread coating to seal them, I've been considering buying them.
#54
Well, this past weekend was warm enough to work in my garage (32 degrees) to try to tackle this project. I replaced the master cylinder and bled all the brake (with only breaking 1 bleeder bolt :-/) But I was able to flush the fluid. Took my car out for the first time in 3 months and stopped like a champ going about 45mph. I haven't yet tested going 60+ but it was completely responsive on the drive I took.
Thanks to everyone that helped with the advice here. I typed up a quick tutorial on changing the master cylinder and I'll get another one for bleeding when I can.
http://www.oldsmobilecentral.com/201...r-cylinder.php
Thanks again
Thanks again
#55
Nice writeup! Glad it worked out well for you.
Also, now you've got another skill, and more confidence and "feel" for when you go after the next one.
And I think $22 beat the bejeezus out of $500 .
You ARE going to change out that cracked hose (and have a close look at the rest of them) before you start really driving it in the spring, right?
#56
I think I'm just going to find all the cheap parts and start replacing. Now that I actually know a little more on what I'm doing, I might as well.
#57
#59
I thought I updated this thread.
The issue was just bad break fluid and a bad master cylinder. I went to advance auto parts and got a new master cylinder for about $20 and new brake fluid. With the help and advice from here, I replaced the master cylinder, flushed the brake fluid, and bled the brakes. Now my car is running and stopping like a champ. Thanks for the help. I saved a couple hundred dollars and learned quite a bit.
I typed up a tutorial of what I did for anyone else that may have this issue:
Kidcutty
July 13th, 2010 05:06 PM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
